ADuC7060 Master code for SPI interfacing
Question asked by poornendu on Mar 22, 2013
Latest reply on Mar 25, 2013 by MMA
I intend to interface multiple devices on SPI bus using ADuC7060. Can you please help me in the code for the same.
I've done following:
//Enable Interrupts
    IRQEN |= BIT10 + BIT11;                     // Enable UART and ADC interrupts
    IRQCONE = BIT1;                                      // Rising edge of XIRQ0
    IRQEN |=  BIT12;                                      // Enable SPI Interrupt
    IRQEN |=  BIT13;                                      // Enable External IRQ0
//Setup SPI interface
    GP0CON0 = BIT0 + BIT4 + BIT8 + BIT12; //Select SPI/I2C alternative function for P0[0...3]
    GP0KEY1 = 0x7; //Write to GP0KEY1
    GP0CON1 &=~ BIT1; //Select SPI functionality for P0.0 to P0.3
    GP0KEY2 = 0x13; //Write to GP0KEY2
SPICON = BIT0 + BIT1 + BIT6         //Enable SPI, Master, MSB First, transfer by write to SPITX,
              + BIT11 + BIT14 + BIT15;  //Continuous transfer, Interuppt after transfer of 4 bytes
I plan to write to SPI using
SPITX = BIT0 + BIT3;
When I run the program SPI interrupt is continuously occuring.
What I'm doing wrong?
What should I do to write 4 bytes to SPI and then disable chip select (SS bar)?
