AD9958 linear sweep problem
Question asked by jeffreyprinzie on Mar 21, 2013
Latest reply on Mar 22, 2013 by jeffreyprinzie
Dear,
I am building a circuit with 2 channels.  Both at fixed frequency but CH1 has a linear phase shift 0-360° and is used as phase interpolator.
The interface to the DDS works. I can program both frequency correctly.
The problem comes when i try the linear sweep with NO-DWELL active.
The code initializes the CTFW0 frequency register to 12.5MHz for both cannels. (that works) .
Then an initialisation code is invoked that writes following registers:
Select channel 1
-CPOW0
     0x0000 (S0)
-CW1
     0xFFFFFFFF   (E0)
-RDW and FDW
     0x00000100
-LSRR (40 ns per increment)
     0x0505
-CFR:
     AFP=11 (phase)
     LinearSweepNoDWELL=1
     LinearSweepEnable=1
     rest is zero  (including open[12:11] bits)
In FR1 is set the profile pin configuration bits all 0, also RU/RD bits, because I dont use modulation.
In the datasheet it is noted tha P1 should be used as profile pin, but I tried all profile pins, no sweep is show, just steady sines at 12.5MHz having constant phase.
do you have any idea what can be wrong?
Specs:
3.3V profile pins
25MHz Xtal
PLLx20
Thanks in advance
Jeffrey
