EPPI Sychronization problem on BF548 EZ-kit
Question asked by PeterHuang on Sep 17, 2009
Latest reply on Nov 6, 2009 by PeterHuang
Hi all,
I am doing a video project,using BF548EZ-Kit and OV7620 image sensor. The sensor is connected directly to the borad via EPPI1 interface. For testing, a single frame  can be captured after setting up the DMA13 and EPPI1 configuration. I use image viewer to display a image with a start address that I specified in the DMA start address. The problem is every time I got a frame, it seems that the image is not sychronized well.It can be seen from the figure I attached below.
The EPPI status register reports a error (EPPIx_STATUS = 0x0024). i.e. Frame Track Underflow Error. When the image I got is correct(the whole frame), the error disappears.  I struggled to figure out where the problem is but without success. My configuration of EPPI1,DMA and port muxing setting is as follow. Any help would be appreciate!
void InitPorts(void)
//activate PortE 14,15 for TWI SDA and SCL
*pPORTE_FER = Px14 | Px15;
ssync();
// set FERF for PPI Data 0-7
*pPORTD_FER = 0x00FF;              //PortD is PPI1
//ssync();
// set FERF for PPI CLK   PORTE is for PCLK(PE11),PFS1(PE12),PFS2
(PE13).
*pPORTE_FER = 0x3800;                 //0011 1000 0000 0000
  ssync();
void InitDMA(void)
*pDMA13_START_ADDR = Frame;          //(0x300000)
*pDMA13_X_COUNT = PIXEL_PER_LINE; //320
*pDMA13_X_MODIFY = 0x1;
*pDMA13_Y_COUNT = LINES_PER_FRAME;   //240
*pDMA13_Y_MODIFY = 0x1;
  *pDMA13_CONFIG = DI_EN | WNR | WDSIZE_8 | DMA2D | AUTOBUFFERMODE;
ssync();
}//end Init_DMA
void InitEPPI1()
    // - EPPI disabled first
    // - EPPI in receive mode
    // - GP 2 mode
    //Skipping enabled
    //FS1 is active high and FS2 is active low, FS1 and FS2 sre
connected to Hsync and Vsync respectively.
    // - sample data on rising edge and sample/drive syncs on rising
edge
    // - DLEN = 8 bits
  *pEPPI1_CONTROL = 0x0006592C;
ssync();
// total lines is 640
    *pEPPI1_LINE = 640;
    ssync();
    //The PPI is set to receive 525 lines for each frame
*pEPPI1_FRAME = 240; // OV7620 default mode is interlace with 240
lines per frame
ssync();
