PWM interrupts on ADSP-21479
Question asked by marc_s1 on Mar 21, 2013
Latest reply on Mar 22, 2013 by Mitesh
The fundamental timing of the interrupt controller is Fpclk / 4. In my case that is 133 MHz / 4 = 33.25 MHz. I have a PWM period corresponding to a frequency of 2.5 MHz (checked on an oscilloscope), so the interrupt controller is running fast enough to latch the PWM interrupts. In my PWM ISR I toggle a DPI output pin, so I expect this pin to be toggled every 400 ns. However, the DPI output pin is toggled every 1 us - 1.5 us and is not in sync with the PWM interrupts!!
Here is how I configured my PWM:
SRU2(PWM1_AH_O, DPI_PB07_I  );           /* connect PWM1 to DPI pin 7  */
SRU2(HIGH,      DPI_PBEN07_I);
*pSYSCTL |= (PWMONDPIEN | PWM1EN);       /* Enable PWM1 module         */
*pPWMGCTL   = PWM_EN1 | PWM_SYNCEN1;   /* PWM1 enable                */
*pPWMCTL1    = 0;                        /* PWM IRQ disable            */
*pPWMPERIOD1 = PWM_PERIOD_CNTS;          /* PWM period register    = 53    */
*pPWMDT1     = 0;                        /* PWM dead time register     */
*pPWMA1       = 0;                        /* PWM channel A duty control */
*pPWMSEG1  = ~(0x04);               /* PWM output enable          */
*pPWMAL1     = 0;                        /* PWM channel AL duty ctrl   */
*pPICR0 &= ~(0x1F << 0);
*pPICR0 |=  (0x18 << 0);
*pPWMCTL1 |= PWM_IRQEN;
interrupt(SIG_P0, pwm_isr);
Here is my PWM ISR:
SRU(HIGH, DPI_PB11_I);
*pPWMGSTAT |= 0x000F; //acknowledge interrupt
SRU(LOW, DPI_PB11_I);
Does anyone have any idea what is causing this behaviour?
Thanks in advance for your support.
Kind regards,
Marc
