adsp-21469: EE345 firmware upload - how to build app?
Question asked by misterdsp on Mar 20, 2013
Latest reply on Apr 3, 2013 by Mitesh
I have the bootloader from EE345. The pdf says to use a CASE 2 type of application code. So I take my regular application, and make it look like the example in "Second Stage Loaders CASE2" directory. Specifically, add 214xx_hdr.asm to my application, and use the same linker file 469_SSL.ldf. Rebuild the application. Upload using the bootloader. The application does copy to flash, but it doesn't run. The pdf says to use a modified boot kernel, but the CASE2 apps are preconfigured to use the default kernel "C:\Program Files\Analog Devices\VisualDSP 5.0\214xx\ldr\469_prom.dxe"
Which .dxe kernel should I use?
Do I also need to add the 214xx_hdr.asm file from "Second Stage Loaders CASE2"
Should I use 469_SSL.ldf from "Second Stage Loaders CASE2"?
