I don't seem to be getting interrupt with AXL345.
Question asked by Mechif on Mar 19, 2013
Latest reply on Apr 4, 2013 by Mechif
I have an application that is supposed to detect sudden jerks. Smooth movement should be ignored.
Below is my setup - though if anyone has a better suggestion, I'm open to hear. I decided not to use Freefall or Tap but just to check extreme values in the X,Y,Z axes. Any high value in any one of the axes should trigger an interrupt.
//ADXL345 Initialization, Register Configuration
void ADXL345_Initiate()
          buf[0] = XL345_RATE_100;                                                            //Output Data Rate: 100Hz
          xl345Write(1, XL345_BW_RATE, buf);
          buf[0] = XL345_FULL_RESOLUTION | XL345_RANGE_16G;//Data Format: +/-16g range, right justified,  256->1g
          xl345Write(1, XL345_DATA_FORMAT, (unsigned char *)buf);
          buf[0] = XL345_FIFO_MODE_STREAM | 5;
          xl345Write(1, XL345_FIFO_CTL, (unsigned char *)buf);
          buf[0] = 0xFD; // x offset -4
          xl345Write(1, XL345_OFSX, (unsigned char *)buf);
          //Delay between each transaction
          __delay_cycles(50);
          buf[0] = 0xFF; // y offset 0
          xl345Write(1, XL345_OFSY, (unsigned char *)buf);
          xl345Read(1, XL345_OFSY , buf);  // offset Y
          __delay_cycles(50);
          buf[0] = 0x3E; // z offset 64//
          xl345Write(1, XL345_OFSZ, (unsigned char *)buf);
          __delay_cycles(50);
          buf[0] = 0;                                        // disable TAP mode
          xl345Write(1, XL345_DUR, (unsigned char *)buf);
          xl345Write(1, XL345_LATENT, (unsigned char *)buf);
           buf[0] = 5;                                        // set THRESH for activity
          xl345Write(1, XL345_THRESH_ACT, (unsigned char *)buf);
          buf[0] = 0;  //all interrupts on PIN1 (P2.4)
          xl345Write(1, XL345_INT_MAP, (unsigned char *)buf);
          buf[0] = 0xFF; //XL345_DATAREADY | XL345_ACTIVITY;  // clear other interrupts - just DATA of X, Y, Z
          xl345Write(1, XL345_INT_ENABLE, (unsigned char *)buf);
  buf[0] = XL345_MEASURE;                                        //Power CTL: Measure mode
          xl345Write(1, XL345_POWER_CTL, (unsigned char *)buf);
           xl345Read(1, XL345_POWER_CTL , buf);  // XL345_POWER_CTL
           // send this msg AGAIN to start
           //xl345Read(1, XL345_POWER_CTL , buf);  // XL345_POWER_CTL
          __delay_cycles(50);
There are somethings that I don't understand - but they work - so I don't argue.
  • I added at the beginning of xl345Write() and xl345Read() a __delay_cycles(50) - but still I need additional delays in the above initialization code.
  • Also, why do I have to call the last command twice (writing the XL345_POWER_CTL)?
I enabled all interrupts, but I don't seem to be getting any.
There may be a HW problem - though I can read the accelerometer values at a rate of 100Hz - and they are logical (according to the motion of the board).
What am i missing/ Why am I not getting interrupts?
Thanks for any help.
Mechi
