21369 SDRAM problem, two 16-bit devices arranged as a single 32-bit
Question asked by AstroMedGlen on Sep 16, 2009
Latest reply on Sep 23, 2009 by AstroMedGlen
      I am experiencing an odd problem with my SDRAM. I have a single 21369 processor attached to two Micron MT48LC16M16 16-bits SDRAM chips. The chips are arranged to function as a single 32-bit device. They are attached via MS1. It appears as though I have some functionality of the memory, but its behavior is a bit bizarre. Every four addresses seem fine, the next four do not, then repeat. For example if I do a mem fill from VDSP of twenty addresses starting at XXXX00 with data 1234ABCD I would get something like:
XXXX00 : 1234ABCD
XXXX01 : 1234ABCD
XXXX02 : 1234ABCD
XXXX03 : 1234ABCD
XXXX04 : 00000000
XXXX05 : 00000000
XXXX06 : 00000000
XXXX07 : 00000000
XXXX08 : 1234ABCD
XXXX09 : 1234ABCD
XXXX0A : 1234ABCD
XXXX0B : 1234ABCD
XXXX0C : 00000000
XXXX0D : 00000000
XXXX0E : 00000000
XXXX0F : 00000000
XXXX10 : 1234ABCD
XXXX11 : 1234ABCD
XXXX12 : 1234ABCD
XXXX13 : 1234ABCD
   I can provide details on pin connections and setup code if need be. Just thought I'd throw this out there first.
Glen
