Can not hear audio in ADV7511 reference design
Question asked by ginachu0508 on Mar 18, 2013
Latest reply on Mar 26, 2013 by DragosB
I use the xilinx board ZC702 to run your reference disign about ADV7511 which provide from your website:
"ADV7511 XILINX EVALUATION BOARDS REFERENCE DESIGN"
It suppose can display an image and play a sound.
After runing the download.bat, I can see the image on the monitor but could not hear any sound.
I also tried to run the HDL reference design and software reference design on xilinx tool SDK, the result is same.
I'v already check the monitor is working well.
Do you have any suggestion for this problem?
Here are the messages shows on the console after running:
  ADI HDMI Trasmitter Application Ver R1.1.1
  HDMI-TX:  ADV7511 Rev 0x12
  Created:  Mar  1 2013 At 15:29:16
Mute audio and video.
APP: Driver Enabled
HPD changed to HI
MSEN changed to HI
A new EDID segment was read.
------------------------- EDID BLOCK 0 -------------------------
Edid Version 1.3
Mon Timing:
    Pixel clock = 148.50 MHz
    H Active    = 1920
    V Active    = 1080
    Progressive
    No stereo
    Separate sync = 3
    +ve VSync
    +ve HSync
Mon Serial: C8LMTF116279
Mon Freq:
    Min V Freq = 50 Hz
    Max V Freq = 75 Hz
    Min H Freq = 24 KHz
    Max H Freq = 83 KHz
Mon Name:   ASUS VS247
Edid extensions blocks: 1
========================= EDID BLOCK 1 =========================
CEA extension block revision 3
Underscan=No  Audio=Yes  YCbCr4:4:4=Yes  YCbCr4:2:2=Yes
Data block collection information:
    Video data block
         VIC=1
         VIC=2
         VIC=3
         VIC=17
         VIC=18
         VIC=19
         VIC=4
         VIC=20
         VIC=5
         VIC=14
         VIC=15
         VIC=29
         VIC=30
         VIC=31
         VIC=16
    Audio data block
       Format Code          = 1 (Linear PCM)
        Max. No. of Channels= 2
        Sampling Freq. (KHz)= 32  44.1  48  96
        Length (bits)       = 16  20  24
    Speaker allocation data block
       0x01
       0x00
       0x00
    VSDB data block
SPA location is at 0xA0, SPA = 1.0.0.0
Mon Timing:
    Pixel clock = 27.0 MHz
    H Active    = 720
    V Active    = 480
    Progressive
    No stereo
    Separate sync = 3
    -ve Vsync
    -ve HSync
Mon Timing:
    Pixel clock = 74.25 MHz
    H Active    = 1280
    V Active    = 720
    Progressive
    No stereo
    Separate sync = 3
    +ve VSync
    +ve HSync
Mon Timing:
    H Active    = 1280
    V Active    = 720
    Progressive
    No stereo
    Separate sync = 3
    +ve VSync
    +ve HSync
Mon Timing:
    H Active    = 720
    V Active    = 576
    Progressive
    No stereo
    Separate sync = 3
    -ve Vsync
    -ve HSync
########################### EDID END ###########################
APP: Changed system mode to Transmitter
Un-mute audio and video.
