AD-FMCOMMS1-EBZ Quick Start Problem - ZYNQ
Question asked by pathfinder on Mar 14, 2013
Latest reply on Mar 18, 2013 by pathfinder
I have created the SD card for the Zedboard Evaluation Kit using the image file zed_xcomm_image_8gb.xz. The kit appears to boot all right, based on the terminal messages being the same as those included in the Quick Start Documentation. However after completing the boot up process neither firefox or the IIO Scope tool start as is suggested they should. The HDMI display simply displays the Ubuntu log in screen. Well, not quite. The HDMI display of the Ubuntu log in screen is not quite right, in that there are rectangles where there should be characters. It is like the language setting is not correct, so the ASCII code for the characters is wrong. The Zedboard is version C. I don't seem to find anyone else on this forum with this problem. Any ideas on what I am doing wrong?
I have included the boot up messages, for completeness.
Machine: Xilinx Zynq Platform, model: Xilinx Zynq ZC702
bootconsole [earlycon0] enabled
Memory policy: ECC disabled, Data cache writealloc
BUG: mapping for 0xf8f00000 at 0xfe00c000 out of vmalloc space
BUG: mapping for 0xe0001000 at 0xfe001000 out of vmalloc space
BUG: mapping for 0xffff1000 at 0xfe200000 out of vmalloc space
PERCPU: Embedded 7 pages/cpu @c0df7000 s6400 r8192 d14080 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 125952
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk ro
otfstype=ext4 rootwait devtmpfs.mount=0
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 240MB 256MB = 496MB total
Memory: 493112k/493112k available, 31176k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xe0800000 - 0xfd000000   ( 456 MB)
    lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0482d54   (4588 kB)
      .init : 0xc0483000 - 0xc04aa900   ( 159 kB)
      .data : 0xc04ac000 - 0xc04e4380   ( 225 kB)
       .bss : 0xc04e43a4 - 0xc09ec78f   (5153 kB)
Preemptible hierarchical RCU implementation.
        RCU lockdep checking is enabled.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:128
xlnx,ps7-ttc-1.00.a #0 at 0xe0800000, irq=43
Console: colour dummy device 80x30
Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
... MAX_LOCKDEP_SUBCLASSES:  8
... MAX_LOCK_DEPTH:          48
... MAX_LOCKDEP_KEYS:        8191
... CLASSHASH_SIZE:          4096
... MAX_LOCKDEP_ENTRIES:     16384
... MAX_LOCKDEP_CHAINS:      32768
... CHAINHASH_SIZE:          16384
memory used by lock dependency info: 3695 kB
per task-struct memory footprint: 1152 bytes
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
smp_twd: clock not found: -2
Calibrating local timer... 333.44MHz.
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
Setting up static identity map for 0x3351c0 - 0x3351f4
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (2664.03 BogoMIPS).
devtmpfs: initialized
------------[ cut here ]------------
WARNING: at arch/arm/mm/dma-mapping.c:198 consistent_init+0x70/0x104()
Modules linked in:
[<c0012dbc>] (unwind_backtrace+0x0/0xe0) from [<c001f510>] (warn_slowpath_common
+0x4c/0x64)
[<c001f510>] (warn_slowpath_common+0x4c/0x64) from [<c001f540>] (warn_slowpath_n
ull+0x18/0x1c)
[<c001f540>] (warn_slowpath_null+0x18/0x1c) from [<c04875b8>] (consistent_init+0
x70/0x104)
[<c04875b8>] (consistent_init+0x70/0x104) from [<c0008668>] (do_one_initcall+0x9
4/0x168)
[<c0008668>] (do_one_initcall+0x94/0x168) from [<c0483850>] (kernel_init+0x84/0x
130)
[<c0483850>] (kernel_init+0x84/0x130) from [<c000e22c>] (kernel_thread_exit+0x0/
0x8)
---[ end trace 1b75b31a2719ed1c ]---
Modules linked in:
+0x4c/0x64)
ull+0x18/0x1c)
x70/0x104)
4/0x168)
130)
0x8)
---[ end trace 1b75b31a2719ed1d ]---
NET: Registered protocol family 16
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72060000, Cache size: 524288 B
registering platform device 'pl330' id 0
registering platform device 'arm-pmu' id 0
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
MIO pin 11 not assigned(00001760)
xslcr xslcr.0: at 0xF8000000 mapped to 0xE0808000
bio: create slab <bio-0> at 0
gpiochip_add: registered GPIOs 0 to 245 on device: xgpiops
xgpiops e000a000.gpio: gpio at 0xe000a000 mapped to 0xe080a000
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
Switching to clocksource xttcpss_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 7, 655360 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 2, 24576 bytes)
UDP-Lite hash table entries: 256 (order: 2, 24576 bytes)
xscugtimer xscugtimer.0: ioremap fe00c200 to e0812200 with size 400
pl330 dev 0 probe success
msgmni has been set to 963
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
e00010øconsole [ttyPS0] enabled, bootconsole disabled
xdevcfg f8007000.devcfg: ioremap f8007000 to e0816000 with size 1000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
GEM: BASEADDRESS hw: e000b000 virt: e0818000
XEMACPS mii bus: probed
xemacps e000b000.eth: invalid address, use assigned
MAC updated 76:5c:03:a0:0f:64
eth0, pdev->id -1, baseaddr 0xe000b000, irq 54
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usb_hcd_xusbps_probe: No OTG assigned!
usb_hcd_xusbps_probe: OTG now assigned!
xusbps-ehci xusbps-ehci.0: Xilinx PS USB EHCI Host Controller
xusbps-ehci xusbps-ehci.0: new USB bus registered, assigned bus number 1
xusbps-ehci xusbps-ehci.0: irq 53, io mem 0x00000000
xusbps-ehci xusbps-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
Xilinx PS USB Device Controller driver (Apr 01, 2011)
cf_axi_adc 79020000.cf-ad9643-core-lpc: Device Tree Probing 'cf-ad9643-core-lpc'
platform 79020000.cf-ad9643-core-lpc: Driver cf_axi_adc requests probe deferral
cf_axi_fft_core 7de00000.cf-fft-core: Device Tree Probing 'cf-fft-core'
cf_axi_fft_core 7de00000.cf-fft-core: Couldn't parse dma-request
cf_axi_fft_core: probe of 7de00000.cf-fft-core failed with error -22
cf_axi_dds 74200000.cf-ad9122-core-lpc: Device Tree Probing 'cf-ad9122-core-lpc'
platform 74200000.cf-ad9122-core-lpc: Driver cf_axi_dds requests probe deferral
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
setting clock to: 108000
raw_edid: d8081180 7
Using YCbCr output
ad9548 spi0.2: Rev. 0xC6 probed
Console: switching to colour frame buffer device 160x64
fb0:  frame buffer device
drm: registered panic notifier
[drm] Initialized analog_drm 1.0.0 20110530 on minor 0
usb 1-1: new full-speed USB device number 2 using xusbps-ehci
ad9523 spi0.3: probed ad9523-lpc
at24 1-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
at24 1-0055: 256 byte 24c02 EEPROM, writable, 1 bytes/write
Linux video capture interface: v2.00
gspca_main: v2.14.0 registered
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: Invalid maximum block size, assuming 512 bytes
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
adv7511 0-0039: Failed to add route DAI IN->TMDS
asoc: adv7511 <-> 75c00000.axi-spdif-tx mapping ok
axi-spdif 75c00000.axi-spdif-tx: Failed to set DAI format: -22
ALSA device list:
  #0: HDMI monitor
TCP cubic registered
VFP support v0.3:
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
implementor 41 architecture 3 part 30 variant 9 rev 4
Registering SWP/SWPB emulation handler
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Waiting for root device /dev/mmcblk0p2...
mmc0: new high speed SDHC card at address 0007
mmcblk0: mmc0:0007 SD8GB 7.42 GiB
mmcblk0: p1 p2
usb 1-1.1: new low-speed USB device number 3 using xusbps-ehci
input: CHICONY HP Basic USB Keyboard as /devices/amba.0/e0002000.usb/xusbps-ehci
.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input0
generic-usb 0003:03F0:0024.0001: input: USB HID v1.10 Keyboard [CHICONY HP Basic
USB Keyboard] on usb-xusbps-ehci.0-1.1/input0
usb 1-1.4: new low-speed USB device number 4 using xusbps-ehci
input: Logitech Optical USB Mouse as /devices/amba.0/e0002000.usb/xusbps-ehci.0/
usb1/1-1/1-1.4/1-1.4:1.0/input/input1
generic-usb 0003:046D:C014.0002: input: USB HID v1.10 Mouse [Logitech Optical US
B Mouse] on usb-xusbps-ehci.0-1.4/input0
o|o- DCI 1
cf_axi_dds 74200000.cf-ad9122-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (0x
10061) at 0x74200000 mapped to 0xe08e0000, probed DDS AD9122
ooooo|oooo----------------------- DCO 0x84
cf_axi_adc 79020000.cf-ad9643-core-lpc: ADI AIM (0x10061) at 0x79020000 mapped t
o 0xe0940000, DMA-0 probed ADC AD9643 as MASTER
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
Freeing init memory: 156K
init: ureadahead main process (684) terminated with status 5
Welcome to Linaro 12.10 (GNU/Linux 3.3.0-01529-gcc8d700-dirty armv7l)
* Documentation:  https://wiki.linaro.org/
2 packages can be updated.
2 updates are security updates.
root@linaro-ubuntu-desktop:~# poweroff
Broadcast message from root@linaro-ubuntu-desktop
        (/dev/ttyPS0) at 0:05 ...
The system is going down for power off NOW!
root@linaro-ubuntu-desktop:~# Checking for running unattended-upgrades:
modem-manager[1491]: <info>  Caught signal 15, shutting down...
System halted.
U-Boot 2010.09-01914-gd2b89cd-dirty (Jan 17 2012 - 17:09:14)
Xilinx Pele Emulation Platform
DRAM:  256 MiB
## Unknown FLASH on Bank 1 - Size = 0x00000000 = 0 MB
Flash: 0 Bytes
MMC:   SDHCI: 0
Using default environment
In:    serial
Out:   serial
Err:   serial
Hit any key to stop autoboot:  0
Copying Linux from SD to RAM...
Device: SDHCI
Manufacturer ID: 41
OEM: 3432
Tran Speed: 25000000
Rd Block Len: 512
SD version 1.10
High Capacity: Yes
Capacity: 7969177600
Bus Width: 1-bit
reading zImage
2531432 bytes read
reading devicetree.dtb
5955 bytes read
reading ramdisk8M.image.gz
Invalid FAT entry
** Unable to read "ramdisk8M.image.gz" from mmc 0:1 **
Trying to set up GEM link...
Resetting PHY...
***Error: Reset stalled...
Waiting for PHY to complete auto-negotiation...
***Error: Auto-negotiation error is present.
ping failed; host 10.10.70.101 is not alive
## Starting application at 0x00008000 ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0
Linux version 3.3.0-01529-gcc8d700-dirty (lars@lars-adi-laptop) (gcc version 4.5
.1 (Sourcery G++ Lite 2010.09-62) ) #4431 SMP PREEMPT Wed Oct 31 17:00:59 CET 20
12
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
NR_IRQS:128
Calibrating local timer... 333.45MHz.
Brought up 2 CPUs
Modules linked in:
+0x4c/0x64)
ull+0x18/0x1c)
x70/0x104)
4/0x168)
130)
0x8)
Modules linked in:
+0x4c/0x64)
ull+0x18/0x1c)
x70/0x104)
4/0x168)
130)
0x8)
TCP reno registered
e0001console [ttyPS0] enabled, bootconsole disabled
brd: module loaded
loop: module loaded
MAC updated 86:5f:13:46:b5:03
composite sync not supported
setting clock to: 65000
raw_edid: d80f47c0 7
Using YCbCr output
Console: switching to colour frame buffer device 128x48
ALSA device list:
  #0: HDMI monitor
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
mmcblk0: p1 p2
o|o- DCI 1
init: ureadahead main process (683) terminated with status 5
        (/dev/ttyPS0) at 0:25 ...
root@linaro-ubuntu-desktop:~# System halted.
