eval-adv7612-7511 not work with some HDMI monitor
Question asked by xtma on Mar 11, 2013
Latest reply on Mar 18, 2013 by mattp
Hello expert
My question is:
  1. how about the firmware of ADSP-BF524 control flow.(configured register of ADV7511/ADV7612)
  2. Can you give us full address setting for ADV7511/ADV7612.(the recommended script in AVES soft is part address setting)
The work mode1 is: 720p@60,video port use RGB, audio 2 channels i2s.
The work mode2 is: 720p@60,video port use RGB, audio 8 channels i2s.
Issue description
  1. It seems the firmware on ADSP-BF524 will auto setting ADV7511/ADV7612 base on
  2. Input video resolution to ADV7612
  3. Input audio sample rate to ADV7612.
The reason is: N of ADV7511 setting different value.
  1. EDID of hdmi monitor connect to ADV7511
The reason is: HDMI/DVI mode of ADV7511 configure on different hdmi monitor.
The reason is: i2s0~3 enable configure on different hdmi monitor.
  1. HPD of hdmi monitor connect to ADV7511
So how about the firmware control flow.
  1. (HDMI Tx)ADV7511 connect to 3 type monitor work ok(asus, philips, etc ).
But there is not display on the hdmi analyzer(astro va-1809). The analyzer seems no video data input.
my puzzle is: is there some error in my setting on ADV7511?(the setting is attached)
Can you give us full ADV7511/ADV7612 setting.
The work mode is: 720p@60,video port use RGB, audio 2 channels i2s.
The work mode is: 720p@60,video port use RGB, audio 8 channels i2s.
Test environment detail:
Hardware:
Quantum data 882EA(2 port HDMI Tx output, the 2 ports can work at the same time)
eval-adv7612-7511 board.
Some hdmi monitor
hdmi analyzer VA-1809
software:
AVES
AVES 2.05.125
AVESserver 1.03 115k
Test Step:
  1. Power up 882EA, set 720p@60 video out, hdmi mode. NO hdcp. Always output video stream.
  2. Power up HDMI monitor, and select hdmi input.
  3. Connect usb cable between PC and eval-adv7612-7511 board.
  4. eval-adv7612-7511,
  5. adv7612 hdmi port Connect to Quantum data 882EA out.
  6. Adv7511 hdmi port connect to HDMI monitor.
  7. Power up eval-adv7612-7511. Plug the power connect to the board.
  8. Open AVES soft
The AVES auto set adv7612 and adv7511 i2c address except IO address.
  1. 6. check the hdmi monitor
There 2 case.(but my operate in above step is the same.)
1) hdmi monitor has normal display
2) hdmi monitor has not normal display
  1. 2.1)Set following  registers
Channel 0 Power Down 0xA1[5]=0 power up
Channel 1 Power Down 0xA1[4]=0 power up
Channel 2 Power Down 0xA1[3]=0 power up
Clock Driver Power Down 0xA1[2]=0 power up
  1. 2.2) there is normal display on the monitor.
Addition: in ADV7511, sometime DVI mode is selected. Sometime HDMI mode is selected.
Sometime I2s0 is enable. I2s1~i2s3 is disable.(use different hdmi monitor)
Sometime i2s0~i2s3 are enable.(use different hdmi monitor)
  1. HPD Control 0xD6 [7:6] = 11 ( HPD is always high).
ADV7511 is not care HPD from hdmi monitor anymore
  1. Connect hdmi cable from ADV7511 to hdmi analyzer.( VA-1809)
The hdmi analyzer detected nothing. There is no change before plug hdmi cable.
  1. Connect hdmi cable from ADV7511 to hdmi monitor. There is normal display on the monitor.
Connect hdmi analyzer to 882EA hdmi tx. The hdmi analyzer can normal display.
Addition test 1:Change ADV7511 with DVI mode.
The hdmi monitor has normal display.
connect to hdmi analyzer, the hdmi analyzer do not have any display.
Addition test2: run the script embedded in AVES for ADV7612-adv7511.
Appendix 1: AVES setting
Appendix 2: AVES log windows display.
>> WRITE port stoprep
>> MEM STORE REPEATER OFF
>> 98 FD 44
>> 98 F4 80
>> 98 FB 68
>> 98 F9 64
>> 98 F5 76
>> 98 F8 4C
>> 98 FA 7C
>> 98 FD  << 44
>> 98 F4  << 80
>> 98 FB  << 68
>> 98 F9  << 64
>> 98 F5  << 76
>> 98 F8  << 4C
>> 98 FA  << 7C
>> 72 45 70
>> 72 E1 78
>> 72 43 7E
>> 72 45 << 70
>> 72 E1 << 78
>> 72 43 << 7E
Thanks
