AD7266 Devicetree support for i.MX28
Question asked by Garfield on Mar 3, 2013
Latest reply on Mar 6, 2013 by Garfield
Branched to a new discussion
I'm an German student writing my thesis, it's about an embedded Linux
controller board with the AD7266 and an i.MX28 SOC.
I am working on Kernel version 3.6.3-rt9 with devicetree support and the AD7266 connected to SPI3.
I have a problem with the initialization of the AD7266. I found the documentation in the wiki [1] but I have no idea where to set up the driver appropriate. The problem is that I couldn't use GPIOs for setting up which channel I would like to sample.
My connections are as follows:
AD7266 A0 => GPIO2_14 of i.MX28
AD7266 A1 => GPIO4_12 of i.MX28
AD7266 A2 => GPIO4_14 of i.MX28
The kernel loads the module for the AD7266 and the connection between SOC and ADC are O.K. but I have no idea where to put the following code snippet so that I could use Single ended mode and dynamic address mode.
      static  struct  ad7266_platform_data pdata =  {
             .range  =  AD7266_RANGE_2VREF,
             .mode  =  AD7266_MODE_SINGLE_ENDED,
             .fixed_addr  =  false,
             .addr_gpios  =  {  GPIO_PF6,  GPIO_PF7,  GPIO_PF8},
I tested to put it in /arch/arm/mach-mxs/mach-mxs.c but this gave me multiple
compilation errors about an missing equation sign (red) and that the
struct is defined but never used.
Another problem is where do I find the appropriate strings for the .addr_gpios
or how do I define all of this in the devicetree?
The interface itself works. I do get raw values for:
     "in_voltage0-voltage1_raw"
     "in_voltage2-voltage3_raw"
The interesting parts of the devicetree "MICS002.dts":
/dts-v1/;
/include/ "imx28.dtsi"
    model = "MICS002 Modul";
    compatible = "fsl,MICS002", "fsl,imx28";
    apb@80000000 {
        apbh@80000000 {
             ssp3: ssp@80016000 {
                #address-cells = <1>;
                #size-cells = <0>;
                compatible = "fsl,imx28-spi";
                pinctrl-names = "default";
                pinctrl-0 = <&spi3_pins_MICS002_ADC>;
                status = "okay";
                AD7266: AD7266@0 {
                    compatible = "adi,ad7266";
                    spi-max-frequency = <100000>;
                    reg = <0>;
                    spi-cpol;
            pinctrl@80018000 {
                spi3_pins_MICS002_ADC: spi3@0 {
                    reg = <0>;
                    fsl,pinmux-ids = <
                        0x2180 /* MX28_PAD_SSP3_SCK__SSP3_SCK */
                        0x2190 /* MX28_PAD_SSP3_MOSI__SSP3_CMD */
                        0x21a0 /* MX28_PAD_SSP3_MISO__SSP3_D0 */
                        0x21b0 /* MX28_PAD_SSP3_SS0__SSP3_D3 */
                    fsl,drive-strength = <1>;
                    fsl,voltage = <1>;
                    fsl,pull-up = <1>;
        apbx@80040000 {
            duart: serial@80074000 {
                pinctrl-0 = <&duart_pins_a>;
                status = "okay";
I hope somebody could help me out or just give me a hint which files I have
to look closer at.
[1]
http://wiki.analog.com/resources/tools-software/linux-drivers/iio-adc/ad7266
Tobias
