Does ADF4351 generate 3.480GHz and 435MHz at RFoutA and RFoutB respectively?
Question asked by serdar on Mar 1, 2013
Latest reply on Mar 7, 2013 by serdar
I want to use both RF out A and B of ADF4351 to drive 2 IC at different clk rate which are 3.480GHz and 435MHz (3480/8). When I check the datasheet, I saw below pin description. But I could not understand If I set the rf divider select register to /8 and FEEDBACK SELECT= 1 (Fundamental ) and AUX OUTPUT SELECT= 0 (DIVIDED OUTPUT)  as below red-lined figure, Does ADF4351 generate 3.480GHz and 435MHz at RFoutA and RFoutB respectively?
Thanks
Serdar
