BF548 SPI DMA receive
Question asked by KPAN on Feb 28, 2013
Latest reply on Mar 20, 2013 by SachinV
Hi All,
I am using BF548 SPI using DMA in master mode.
I have interfaced AD7357 with BF548. Everything is working properly.
I am continuously getting the sample data in buffer.
I want to analyse every sample when it is received apply some algorithm and save the data in DDRRAM and SD card.
As it is DMA transfer I am thinking where should I write the code for analyzing the samples.
As I want to use SPI at maximum speed, it is very difficult to sync with he speed.
Where should i write the codefor analysing each sample?
#define BUFFER_COUNT (4)
#define DATA_COUNT (2048)
static u16 Data[DATA_COUNT * BUFFER_COUNT];
static ADI_DEV_1D_BUFFER Buffer[BUFFER_COUNT];
static ADI_DEV_DEVICE_HANDLE SPIHandle;
  ADI_DEV_CMD_VALUE_PAIR SPIConfig[] = {
{ ADI_DEV_CMD_SET_DATAFLOW_METHOD, (void *)ADI_DEV_MODE_CHAINED_LOOPBACK }, // chained loopback
{ ADI_SPI_CMD_SET_BAUD_REG, (void *)0x12 }, // run at some rate
{ ADI_SPI_CMD_SET_WORD_SIZE, (void *)16 }, // word size 16 bits
{ ADI_SPI_CMD_ENABLE_SLAVE_SELECT, (void *)3 }, // device is on SS 4
{ ADI_SPI_CMD_SELECT_SLAVE, (void *)3 }, // enable the device
{ ADI_SPI_CMD_SET_CONTROL_REG, (void *)0x1122},
{ ADI_DEV_CMD_END, NULL }
Result = adi_dev_Open(adi_dev_ManagerHandle, &ADISPIDMAEntryPoint, 0, 0, &SPIHandle,
ADI_DEV_DIRECTION_INBOUND, adi_dma_ManagerHandle, NULL, &Callback);
Result = adi_dev_Control(SPIHandle, ADI_DEV_CMD_TABLE, SPIConfig);
for (i = 0; i < BUFFER_COUNT; i++) {
Buffer[i].Data = &Data[i * DATA_COUNT];
Buffer[i].ElementCount = DATA_COUNT;
Buffer[i].ElementWidth = 2;
Buffer[i].CallbackParameter = NULL;//&Buffer[i];
Buffer[i].pNext = &Buffer[i+1];
Buffer[i-1].pNext = NULL;
  Result = adi_dev_Read(SPIHandle, ADI_DEV_1D, (ADI_DEV_BUFFER *)Buffer);
Result = adi_dev_Control(SPIHandle, ADI_DEV_CMD_SET_DATAFLOW, (void *)TRUE);
while(1)
Data[8192] is the array in which I am receiving samples.
If I access all the elements from while(1) in a loop to write it into SD card, speed is not syncronising and shape of the waveform is distorted in excel sheet because of repeating/missing samples.
Can you help me with the same?
Thanks in advance.
KP
