Unable to start New Project Wizard in CCES
Question asked by MZC on Feb 28, 2013
Latest reply on Feb 28, 2013 by amcl
I am facing problem to start new project wizard in new workspace using CCES. Although I am able to import existing project in new workspace but when i tried to start new project wizard, some plugin errors come up as shown below. Help regarding this issue will be helpful.
mussab
!SESSION 2013-02-28 09:30:18.437 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_27
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments:  -os win32 -ws win32 -arch x86 -data C:\User\Test
!ENTRY org.eclipse.jface 4 2 2013-02-28 11:00:47.765
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
java.lang.NoClassDefFoundError: com/analog/crosscore/system/components/datasource/IComponentDataSource
    at com.analog.crosscore.managedbuilder.ui.newprojectwizard.NewProjectWizard.init(Unknown Source)
    at org.eclipse.ui.internal.dialogs.WorkbenchWizardNode.getWizard(WorkbenchWizardNode.java:185)
    at org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(WizardSelectionPage.java:104)
    at org.eclipse.ui.internal.dialogs.WorkbenchWizardSelectionPage.getNextPage(WorkbenchWizardSelectionPage.java:100)
    at org.eclipse.ui.internal.dialogs.NewWizardSelectionPage.advanceToNextPageOrFinish(NewWizardSelectionPage.java:71)
    at org.eclipse.ui.internal.dialogs.NewWizardNewPage$1.doubleClick(NewWizardNewPage.java:364)
    at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:845)
    at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
    at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
    at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
    at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:843)
    at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1462)
    at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1246)
    at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:249)
    at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:246)
    at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:307)
    at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
    at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
    at org.eclipse.jface.window.Window.open(Window.java:801)
    at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:257)
    at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:277)
    at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
    at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
    at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
    at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
    at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
    at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
    at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
    at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
    at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
    at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
    at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.analog.crosscore.system.components (44).
    at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
    at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:463)
    at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
    at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
    at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
    at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
    at java.lang.ClassLoader.loadClass(Unknown Source)
    at com.analog.crosscore.ui.UIStartup$1.run(Unknown Source)
    at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
    at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
    ... 20 more
Caused by: org.osgi.framework.BundleException: Exception in com.analog.crosscore.system.components.SystemComponentPlugin.start() of bundle com.analog.crosscore.system.components.
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
    at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
    at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
    at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
    at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
    at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
    ... 34 more
Caused by: java.lang.IllegalStateException: Profile not locked due to exception: C:\Analog Devices\CrossCore Embedded Studio 1.0.1\Eclipse\p2\org.eclipse.equinox.p2.engine\profileRegistry\CCESProfile.profile\.lock (Zugriff verweigert)
    at org.eclipse.equinox.internal.p2.engine.ProfileLock.lock(ProfileLock.java:106)
    at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.restore(SimpleProfileRegistry.java:441)
    at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfileMap(SimpleProfileRegistry.java:277)
    at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.internalGetProfile(SimpleProfileRegistry.java:238)
    at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfile(SimpleProfileRegistry.java:168)
    at com.analog.crosscore.system.utility.P2Utils.getP2Profile(Unknown Source)
    at com.analog.crosscore.system.utility.P2Utils.getP2ExtensionLocations(Unknown Source)
    at com.analog.crosscore.system.components.SystemComponentManager.loadAllComponents(Unknown Source)
    at com.analog.crosscore.system.components.SystemComponentPlugin.start(Unknown Source)
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
    at java.security.AccessController.doPrivileged(Native Method)
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
    ... 40 more
