ADXL345 multi-byte read doesnt work
Question asked by pentelone on Feb 26, 2013
Hello everone,
i try to read values form ADXL345 in multi byte transmision.
Before reading i write some values to  ADXL345s registers and verify if they are correct. Next i try to read registers :
as i undarstand from datasheet (rev.c.) to read multiple byte i must set R value as high and MB high pass the address of register and then set 8 clock pulses to indicate next register so here's the code:
ADXL345_SELECT();
SSIDataPut(SSI0_BASE, 0xC000 | (reg<<8));
SSIDataGet(SSI0_BASE,&get_data);
SSIDataPut(SSI0_BASE,0x00);
ADXL345_DESELECT();
so the result is that i've got the same value during reading ADXL345's registers. uC is Stellaris LM4F120
Could you point me where is the problem ?
