Linux hangs on boot while mounting root file system on SD card
Question asked by Mike-Przybylski on Feb 23, 2013
Latest reply on Apr 2, 2013 by larsc
The recent updates to the analog devices linux repository seem to have broken the SD/MMC drivers for the ZED Board.  (Xilinx Zynq).
I am using the xcomm_zynq branch and the most recent commit was:
d7e18dfa171e5b6eab02ba22498822f8f09d3f89
I am also using Xilinx's latest version of U-Boot, (2012.10).  Since I had to make a few changes to the zync_xcomm_adv7511_defconfig, I am attaching a copy of my kernel config.
I used  the zynq-zed-adv7511.dts file to generate my device tree.
I am really new to linux driver troubleshooting and kernel hacking, but I would love some pointers on how to understand and fix this problem.
Best regards
Mike P.
Console from startup to boot hang:
U-Boot 2012.10 (Feb 07 2013 - 00:21:48)
DRAM:  512 MiB
MMC:   SDHCI: 0
SF: Detected S25FL256S with page size 64 KiB, total 32 MiB
SF: Warning - Only lower 16MB is accessible in 3 byte addressing mode
In:    serial
Out:   serial
Err:   serial
Net:   zynq_gem
Hit any key to stop autoboot:  0
copy kernel from sd to ram...
Device: SDHCI
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 29.7 GiB
Bus Width: 4-bit
reading uImage
2737632 bytes read
reading devicetree.dtb
6920 bytes read
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-3.6.0-02477-gd7e18df
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2737568 Bytes = 2.6 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x02a00000
   Loading Kernel Image ... OK
OK
   Loading Device Tree to 1fb50000, end 1fb54b07 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0
Linux version 3.6.0-02477-gd7e18df (mikep@debbie-does-linus) (gcc version 4.6.3 (Sourcery CodeBench Lite 2012.03-79) ) #7 SMP PREEMPT Fri Feb 22 18:54:47 PST 2013
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Xilinx Zynq Platform, model: Xilinx Zynq ZED
bootconsole [earlycon0] enabled
cma: CMA: reserved 40 MiB at 1d000000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @c0e33000 s7872 r8192 d12608 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 512MB = 512MB total
Memory: 468220k/468220k available, 56068k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
    lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc04ab1bc   (4749 kB)
      .init : 0xc04ac000 - 0xc04d3ec0   ( 160 kB)
      .data : 0xc04d4000 - 0xc0521720   ( 310 kB)
       .bss : 0xc0521744 - 0xc0a28550   (5148 kB)
Preemptible hierarchical RCU implementation.
        RCU lockdep checking is enabled.
        Dump stacks of tasks blocking RCU-preempt GP.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
NR_IRQS:512
MIO pin 11 not assigned(00001760)
xslcr mapped to e0802000
Zynq clock init
timer #0 at e0804000, irq=43
sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
Console: colour dummy device 80x30
Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
... MAX_LOCKDEP_SUBCLASSES:  8
... MAX_LOCK_DEPTH:          48
... MAX_LOCKDEP_KEYS:        8191
... CLASSHASH_SIZE:          4096
... MAX_LOCKDEP_ENTRIES:     16384
... MAX_LOCKDEP_CHAINS:      32768
... CHAINHASH_SIZE:          16384
memory used by lock dependency info: 3695 kB
per task-struct memory footprint: 1152 bytes
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
Setting up static identity map for 0x34ed50 - 0x34ed84
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72360000, Cache size: 524288 B
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (2664.03 BogoMIPS).
devtmpfs: initialized
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
xgpiops e000a000.gpio: gpio at 0xe000a000 mapped to 0xe080c000
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.25.
Switching to clocksource xttcps_clocksource
NET: Registered protocol family 2
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 7, 589824 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP: reno registered
UDP hash table entries: 256 (order: 2, 20480 bytes)
UDP-Lite hash table entries: 256 (order: 2, 20480 bytes)
msgmni has been set to 994
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
xuartps e0001000.uart: failed to get alias id, errno -19
e000�console [ttyPS0] enabled, bootconsole disabled
xdevcfg f8007000.devcfg: ioremap f8007000 to e0812000 with size 1000
[drm] Initialized drm 1.1.0 20060810
platform 6c000000.axi_hdmi: Driver axi-hdmi requests probe deferral
brd: module loaded
loop: module loaded
xqspips e000d000.spi: master is unqueued, this is deprecated
xqspips e000d000.spi: at 0xE000D000 mapped to 0xE0814000, irq=51
libphy: XEMACPS mii bus: probed
xemacps e000b000.eth: pdev->id -1, baseaddr 0xe000b000, irq 54
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ULPI transceiver vendor/product ID 0x0451/0x1507
Found TI TUSB1210 ULPI transceiver.
ULPI integrity check: passed.
xusbps-ehci xusbps-ehci.0: Xilinx PS USB EHCI Host Controller
xusbps-ehci xusbps-ehci.0: new USB bus registered, assigned bus number 1
xusbps-ehci xusbps-ehci.0: irq 53, io mem 0x00000000
xusbps-ehci xusbps-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: Invalid maximum block size, assuming 512 bytes
mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
adv7511-hdmi-snd adv7511_hdmi_snd.4: CODEC adv7511.2-0039 not registered
platform adv7511_hdmi_snd.4: Driver adv7511-hdmi-snd requests probe deferral
mmc0: new high speed SDHC card at address e624
TCP: cubic registered
VFP support v0.3: mmcblk0: mmc0:e624 SU32G 29.7 GiB
implementor 41 architecture 3 part 30 variant 9 rev 4
Registering SWP/SWPB emulation handler
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
No connectors reported connected with modes
[drm] Cannot find any crtc or sizes - going 1024x768
ALSA device list:
  No soundcards found.
�Console: switching to colour frame buffer device 128x48
fb0:  frame buffer device
drm: registered panic notifier
[drm] Initialized axi_hdmi_drm 1.0.0 20120930 on minor 0
mmc0: Timeout waiting for hardware interrupt.
mmcblk0: error -110 transferring data, sector 90376, nr 264, cmd response 0x900, card status 0xb00
mmcblk0: retrying using single block read
mmcblk0: error -110 transferring data, sector 90432, nr 208, cmd response 0x900, card status 0x0
end_request: I/O error, dev mmcblk0, sector 90432
mmcblk0: error -110 transferring data, sector 90433, nr 207, cmd response 0x900, card status 0x0
end_request: I/O error, dev mmcblk0, sector 90433
INFO: task swapper/0:1 blocked for more than 20 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
swapper/0       D c034d62c     0     1      0 0x00000000
[<c034d62c>] (__schedule+0x540/0x658) from [<c034d938>] (io_schedule+0x70/0xa0)
[<c034d938>] (io_schedule+0x70/0xa0) from [<c00d4e40>] (sleep_on_buffer+0x8/0x10)
[<c00d4e40>] (sleep_on_buffer+0x8/0x10) from [<c034b28c>] (__wait_on_bit+0x54/0x9c)
[<c034b28c>] (__wait_on_bit+0x54/0x9c) from [<c034b34c>] (out_of_line_wait_on_bit+0x78/0x84)
[<c034b34c>] (out_of_line_wait_on_bit+0x78/0x84) from [<c013706c>] (journal_get_superblock+0x50/0x2a8)
[<c013706c>] (journal_get_superblock+0x50/0x2a8) from [<c01372d0>] (load_superblock+0xc/0x58)
[<c01372d0>] (load_superblock+0xc/0x58) from [<c013733c>] (jbd2_journal_wipe+0x20/0x94)
[<c013733c>] (jbd2_journal_wipe+0x20/0x94) from [<c0116c4c>] (ext4_fill_super+0x1cc8/0x26c4)
[<c0116c4c>] (ext4_fill_super+0x1cc8/0x26c4) from [<c00af7d4>] (mount_bdev+0x120/0x19c)
[<c00af7d4>] (mount_bdev+0x120/0x19c) from [<c011163c>] (ext4_mount+0x10/0x18)
[<c011163c>] (ext4_mount+0x10/0x18) from [<c00b00b0>] (mount_fs+0x10/0xb0)
[<c00b00b0>] (mount_fs+0x10/0xb0) from [<c00c7e80>] (vfs_kern_mount+0x4c/0xc0)
[<c00c7e80>] (vfs_kern_mount+0x4c/0xc0) from [<c00c831c>] (do_kern_mount+0x34/0xd0)
[<c00c831c>] (do_kern_mount+0x34/0xd0) from [<c00c9df0>] (do_mount+0x628/0x6a8)
[<c00c9df0>] (do_mount+0x628/0x6a8) from [<c00c9ef4>] (sys_mount+0x84/0xc4)
[<c00c9ef4>] (sys_mount+0x84/0xc4) from [<c04acb94>] (mount_block_root+0xec/0x288)
[<c04acb94>] (mount_block_root+0xec/0x288) from [<c04acfd4>] (prepare_namespace+0x160/0x1c0)
[<c04acfd4>] (prepare_namespace+0x160/0x1c0) from [<c04ac964>] (kernel_init+0x178/0x1b8)
[<c04ac964>] (kernel_init+0x178/0x1b8) from [<c000e388>] (kernel_thread_exit+0x0/0x8)
1 lock held by swapper/0/1:
#0:  (&type->s_umount_key#12/1){+.+.+.}, at: [<c00af3e4>] sget+0x29c/0x4d4
mmcblk0: error -110 transferring data, sector 90434, nr 206, cmd response 0x900, card status 0x0
end_request: I/O error, dev mmcblk0, sector 90434
mmcblk0: error -110 transferring data, sector 90435, nr 205, cmd response 0x900, card status 0x0
end_request: I/O error, dev mmcblk0, sector 90435
