AD9789 not initialized reliably
Question asked by plg on Feb 22, 2013
Latest reply on Jun 10, 2013 by danf
We've designed a board using the AD9789, and the DAC doesn't always start up correctly.
About  1 of 10 initializations the AD9789 suddenly starts to work correctly, the other
9 times it seems to work, the amplitude spectrum seems ok, but the phases (OFDM) are
completely messed.
Also about 9 out of 10 times I get no Framesync (FS=0), while I expect a constant FS=1,
since sample rate = DCO clock = 32 MHz. On top of that FS=1 and DAC giving a correct
output signal seem unrelated.
The current workaround is to have a keyboard key that reinitializes the DAC, and I need
to push this key many times until the DAC output signal is correct.
Parity checking is enabled - no parity errors in the Parity Counter Register, so I assume
the data side clocking is correct. SPI Clock is 5 kHz. Reading
back the SPI registers shows that it's correctly written, and there is no difference
between a working and a non-working session of the DAC in terms of readback register contents.
This is the init-sequence:
----------> snip
reset dac (reset pin)
wait 100ms
release dac reset (reset pin)
wait 100ms
write_dac[0x32] =  0x9e
write_dac[0x30] =  0x80
write_dac[0x24] =  0x00
write_dac[0x24] =  0x80
write_dac[0x2f] =  0xce
write_dac[0x33] =  0x42
write_dac[0x39] =  0x4e
write_dac[0x3a] =  0x6c
write_dac[0x03] =  0x00
write_dac[0x04] =  0xfe
write_dac[0x03] =  0x0c
write_dac[0x33] =  0x43
write_dac[0x06] =  0xc7
write_dac[0x07] =  0x07
write_dac[0x08] =  0x40
write_dac[0x09] =  0x20
write_dac[0x0c] =  0xf7 0xff 0xfe
write_dac[0x0f] =  0x00 0x00 0x00
write_dac[0x12] =  0x00 0x00 0x00
write_dac[0x15] =  0x00 0x00 0x00
write_dac[0x18] =  0x00 0x00 0x0a
write_dac[0x1b] =  0x00 0x00 0x0a
write_dac[0x1d] =  0x1f 0x80
write_dac[0x20] =  0x08
write_dac[0x21] =  0x78
write_dac[0x22] =  0x40
write_dac[0x23] =  0x00
write_dac[0x25] =  0x80
write_dac[0x26] =  0x80
write_dac[0x27] =  0x80
write_dac[0x28] =  0x80
write_dac[0x29] =  0x01
write_dac[0x3c] =  0x14
write_dac[0x3d] =  0x00
read_dac[0x04] = 0x08
write_dac[0x1e] =  0x80
write_dac[0x05] =  0x01
write_dac[0x00] =  0x18
write_dac[0x31] =  0xf0
write_dac[0x36] =  0x00
write_dac[0x38] =  0x02
write_dac[0x3e] =  0x30
Any ideas why the DAC won't start properly at every power-on?
