AD-FMCOMMS1-EBZ  No OS Ref Design - ADC Function : Sample Location
Question asked by DrTom on Feb 20, 2013
Latest reply on Sep 5, 2013 by ACozma
Can anyone explain the macro call "   Xil_Out32((baddr + 0x058), (qwcnt * 8)); // number of bytes" shown below from the test.c file. I assume it is capturing two channels of 14 bit data(each) from the ADC and storing them in DDR3 memory via the DMA. If that is true, why does the code tell the DMA that it is passing "qwcnt*8" bytes instead of "qwcnt*4" bytes?  And how is each channel placed in memory i.e. if it is really writing 64 bits to memory, which bits are channel 1 and which are channel 2?
Thanks...Tom
ref:
void adc_capture(uint32_t sel, uint32_t qwcnt, uint32_t sa)
{ //See
    uint32_t baddr;
    baddr = (sel == IICSEL_B1HPC) ? DMA9643_1_BASEADDR : DMA9643_0_BASEADDR;
    Xil_Out32((baddr + 0x030), 0); // clear dma operations
    Xil_Out32((baddr + 0x030), 1); // enable dma operations
    Xil_Out32((baddr + 0x048), sa); // capture start address
    baddr = (sel == IICSEL_B1HPC) ? CFAD9643_1_BASEADDR : CFAD9643_0_BASEADDR;
    Xil_Out32((baddr + 0x00c), 0x0); // capture disable
    Xil_Out32((baddr + 0x010), 0xf); // clear status
    Xil_Out32((baddr + 0x014), 0xf); // clear status
    Xil_Out32((baddr + 0x00c), (0x10000 | (qwcnt-1))); // start capture
  do
        delay_ms(1);
    while ((Xil_In32(baddr + 0x010) & 0x1) == 1);
    if ((Xil_In32(baddr + 0x010) & 0x02) == 0x02)
        xil_printf("adc_capture: overflow occured, data may be corrupted\n\r");
#ifdef _XPARAMETERS_PS_H_
    Xil_DCacheFlush();
#else
    microblaze_flush_dcache();
    microblaze_invalidate_dcache();
#endif
