ADV7393: Black output under 8-bit 625i YCrCb (EAV/SAV) input
Question asked by DirkFranzen on Feb 18, 2013
Latest reply on Mar 8, 2013 by mattp
I was running the ADV7393 und 8-bit 525i YCrCb (EAV/SAV) input with CVBS output using the settings below and everything worked fine.
8-bit 525i YCrCB (EAV/SAV) in CVBS out (Table 65)
RegisterValue
0x170x02
0x000x1C
0x010x00
0x800x10
0x820xCB
Recently I switched to 8-bit 625i YCrCb (EAV/SAV) input with CVBS output and took the settings below.
8-bit 625i YCrCb (EAV/SAV) in, CVBS out (Table 82)
Register
Value
0x170x02
0x000x1C
0x010x00
0x800x12
0x820xC3
0x8C0xCB
0x8D0x8A
0x8E0x09
0x8F0x2A
but I'm just getting a a black picture. I've checked the PAL output by using the colorbar testpattern on the ADV7393 and the output works fine. On the input side the digital signal looks exaktly as it should. I've also checked the digital picture and it looks like expected
Input Clock is 27 MHz, VSYNC is at 50 Hz, an HSYNC at 15.625 kHz. Which leads to 864 pixels horizontal and 625 pixels vertical
The SFL pin is floating, since I'm setting the subcarrier registers. I believe it shouldn't be neccessary to connect the SFL pin or should it be connected to ground?
Thanks for your help
Dirk
