UART program doesnt run from Flash
Question asked by Naik on Feb 18, 2013
I have written a simple code to test UART interface for ADSP-EZkit BF533 processor.
The code builds and runs successfully when I select "Executable" as the target type and run it in debug mode.
But when I select "Loader" as the target type and load it onto the Flash using Flash programmer, the code doesnt run.
Following is the code -
* TryPgm.c
#include <cdefBF533.h>
#include <ccblkfn.h>
#include <stdlib.h>
#define DIVISOR   586
void main()
int get_val;
init_PLL();
init_uart();
//get_val = UART_getc();
    UART_puts("Hello Pradnya",13);
void init_PLL(void)
//PLL control, CLKIN is 38.4 //27 MHz
*pPLL_CTL = 0x1B;
//PLL DIV
*pPLL_DIV = 0x3; // SSEL is 4, which gives: SCLK of 100 MHz< 133 MHz
                        //SSEL changed to 3
void init_uart(void)
//Enable uart clock
   *pUART_GCTL = UCEN;
//Enable access to UART_DLL and UART_DLH
*pUART_LCR  = DLAB;
//Write baud rate to the two 8-bit DL registers
*pUART_DLL  = (DIVISOR);
*pUART_DLH  = (DIVISOR >> 8);
//Clear DLAB and set UART frame to 8 bits, no parity and 1 stop bit
*pUART_LCR = 0x03;
void  UART_putc(char value)
while(!(*pUART_LSR & THRE))
  //Wait
*pUART_THR = value;
char UART_getc(void)
char cVal;
while(!(*pUART_LSR & DR))
  //Wait
cVal = *pUART_RBR;
return cVal;
void UART_puts(char *pData,int nLen)
int nIndx;
for(nIndx=0; nIndx<nLen; nIndx++)
  UART_putc(*pData);
  pData++;
void UART_gets(char *str,int len)
int nCnt;
for(nCnt = 0; nCnt < len; nCnt++)
  str[nCnt] = UART_getc();
This code prints the "Hello Pradnya" on Hyperterminal when run in debug mode but not when executed from Flash.
Please help.
Pradnya
