Error while connecting to target using HPUSB-ICE emulator
Question asked by Naik on Feb 18, 2013
Latest reply on Feb 18, 2013 by Naik
I am using ADSP-BF533 EZ-KIt lite with VisualDSP++ 5.0 and HPUSB-ICE Emulator.
I programmed my code on the flash using the flash programmer utility and the flash driver provided in the example codes.
After programming, the code does not run properly. When I tried to load the flash driver again, it gave an error "Reset failed. Disconnect from the IDDE." and crashed. After this I am unable to connect to the target using the existing session, it throws the following error:
When I run the ICE test It fails at "Opening emulator interface" step as follows:
The session was working fine before flash programming and the ICE test was passing.
Please help.
Pradnya
