Between EEPROM write and read need a delay
Question asked by danielc@nexsens.com on Feb 14, 2013
Latest reply on Mar 12, 2013 by MMA
I use I2C to control a external EEPROM. Now my problem is that between the writing and reading, I need a delay(0x2f00), otherwise, it can not read. It is same if I invoke two write command, the second write command will stuck. But if I just invoke a read command no write command, it works. I did not use interrupt, the following code is my code.
Any ideas about this?
Thank you.
void delay (long int length)
  while (length >0)
    length--;
void I2C_EE_RdByte(unsigned int uiAddr,unsigned char *ucByte)
    I2cFifoFlush(MASTER,ENABLE);        // Flush FIFO buffer
    I2cFifoFlush(MASTER,DISABLE);
    unsigned char ucHiAddr = (unsigned char)((uiAddr >>8)&0x00ff);
    unsigned char ucLoAddr = (unsigned char)(uiAddr & 0x00ff);
    I2cTx(MASTER,ucHiAddr);             // Send address MSB
    I2cTx(MASTER,ucLoAddr);             // Send address LSB
    I2cMWrCfg(0xA0);
   while( ( I2cSta(MASTER) & I2CMSTA_TXFSTA_MSK ) != I2CMSTA_TXFSTA_EMPTY ){}   // If no that delay, it will stuck here
                                // Wait for FIFO empty
    I2cMRdCfg(0xA0,1,DISABLE);  // Send read one byte command
    while((I2cSta(MASTER) & I2CMSTA_TCOMP_SET) != I2CMSTA_TCOMP_SET){}
    *ucByte = I2cRx(MASTER);
void I2C_EE_WrByte(unsigned int uiAddr,unsigned char ucVal)
    unsigned char ucTxIndex = 0;
    unsigned char ucTxDat[3];
    ucTxDat[0] = ucHiAddr;
    ucTxDat[1] = ucLoAddr;
    ucTxDat[2] = ucVal;
    I2cFifoFlush(MASTER,ENABLE);        // Flush the FIFO buffer
    I2cMWrCfg(0xA0);
    I2cTx(MASTER, ucTxDat[ucTxIndex++]);    // send 1st data
    ucComplete = 0;
    while(ucComplete == 0)
                                // Wait for FIFO buffer empty
        if(ucTxIndex < 3)       //Check if send out all data
        else
            ucComplete = 1;
    delay(0x3000);   // If there is no this delay, for the reading behind this write command, it will stuck in read status part
int main(void)
    WdtGo(T3CON_ENABLE_DIS);
    DioCfg(pADI_GP2, 0x05);       // Configure P2.0/P2.1 as I2C pins
    DioPul(pADI_GP2, 0xFC);       // External pull ups required externally
    pADI_GP1->GPOEN = 0x1;
    // configure the clocks
    ClkCfg(CLK_CD0,CLK_HF,CLKSYSDIV_DIV2EN_DIS,CLK_UCLKCG);
    ClkSel(CLK_CD0,CLK_CD0,CLK_CD0,CLK_CD0);
    ClkDis(CLKDIS_DISSPI0CLK|CLKDIS_DISSPI1CLK|CLKDIS_DISUARTCLK|CLKDIS_DISPWMCLK|
              CLKDIS_DIST0CLK|CLKDIS_DIST1CLK|CLKDIS_DISDACCLK|CLKDIS_DISDMACLK|CLKDIS_DISADCCLK);
    I2cMCfg(I2CMCON_TXDMA_DIS|I2CMCON_RXDMA_DIS,  0, I2CMCON_MAS_EN);
    I2cBaud(0x1E,0x1F); // 400kHz clock
    unsigned char ucVal;
    I2C_EE_WrByte(0x000,0x88);
    // if no delay, this read does not work
    I2C_EE_RdByte(0x000,&ucVal);
    printf("content is %x\n",ucVal);
