Get 'make' errors using 2011R1 pre-built tools and default uclinux-dist
Question asked by ShutEyeThinkin on Feb 13, 2013
Latest reply on Feb 18, 2013 by Aaronwu
Getting compile errors.
Host: Ubuntu
I have downloaded and installed the pre-built tools:
                blackfin-toolchain-2011R1-RC4.i386.tar.bz2
                blackfin-toolchain-elf-gcc-4.3-2011R1-RC4.i386.tar.bz2
and downloaded and installed the following uclinux-dist:
                blackfin-linux-dist-2011R1-RC3.tar.bz2
The pre-built tools were extracted and placed into the /opt folder:
opt/
     /bfin-elf
     /bfin-linux-uclibc
     /bfin-uclinux
The paths are set to the /bin folder in each.
Executed 'make menuconfig' without any changes.
I get errors very quickly after executing 'make'.   See attached file.
My understanding is that I should be able to use the pre-built tools 2011R1-R4 to make
the default uclinux-dist 2011R1-RC3 with little chance of errors.
As a test, if I use my older, very reliable toolchain (2009), it compiles the 2011R1 files for quite a while before failing.
So something must be amiss with the 2011R1 tools.
Thanks
ShutEyeThinkin.
