ADV7181C RGsB Conversion
Question asked by rsavage on Feb 12, 2013
Latest reply on Jul 1, 2013 by HongZhengWei
I have an ADV7181C which I have been using to convert CVBS and Y\C Video to 20bit 4:2:2.
I am now trying to convert RGsB to the same format.
I am using the following script. I am sure this was working in the past but having returned to the RGsB input I cannot now get it to work.
I require a LLC of 13.5MHz.
My script is as follows:
##CP 625i##
:625i/50Hz RGsB In 20Bit 422 EAV/SAV out Encoder:
42 C3 56 ; Red on AIN5, SOGreen on AIN6
42 C4 84 ; ADCs I/Ps to Manual Switching; Blue on AIN4
42 03 04 ; 20-bit 4:2:2 Output
42 04 4B ; Force HS, VS and F Output Pins Active
42 05 00 ; Prim_Mode = 0000b for SD-M
42 06 0B ; VID_STD = 1011b for SD 625i 4x1 (720 x 480)
42 1D 47 ; Enable 28.63636MHz External Crystal
42 3A 11 ; Set Latch Clock to 0001b (LLC = 13.5MHz to 55MHz), Power Down ADC3 (Not Used)
42 3B 81 ; Enable internal Bias
42 3C 5A ; PLL_QPUMP to 010b (With 05 and 06 sets PLL Divisor and VCO Range Automatically)
42 52 00 ; CSC_1  Channel A Offset = 0 Colour Space Conversion from RGB->YCrCb, No 2x Scaling
42 53 00 ; CSC_2
42 54 12 ; CSC_3  Channel A3 Coefficient = 1188
42 55 90 ; CSC_4  Channel A2 Coefficient = 451
42 56 38 ; CSC_5
42 57 69 ; CSC_6  Channel A1 Coefficient = 2376
42 58 48 ; CSC_7
42 59 08 ; CSC_8  Channel B Offset = 2048
42 5A 00 ; CSC_9
42 5B 75 ; CSC_10 Channel B3 Coefficient = 7496
42 5C 21 ; CSC_11 Channel B2 Coefficient = 2048
42 5D 00 ; CSC_12
42 5E 1A ; CSC_13 Channel B1 Coefficient = 6840
42 5F B8 ; CSC_14
42 60 08 ; CSC_15 Channel C Offset = 2048
42 61 00 ; CSC_16
42 62 20 ; CSC_17 Channel C3 Coefficient = 2048
42 63 03 ; CSC_18 Channel C2 Coefficient = 7866
42 64 D7 ; CSC_19
42 65 19 ; CSC_20 Channel C1 Coefficient = 6472
42 66 48 ; CSC_21 last
42 67 13 ; DPP Filters on Channels B & C have shallow role-off in transition band,
         ; Channels A, B and C Oversampled by 2 & Channel A Decimated by 2,
         ; Channels B & C Decimated by 4, giving a 4:2:2 Output
42 6B C1 ; HSync and Field Sync Output Pins Enabled. Select 20-bit YPrPb Output from CP
42 73 CF ; Enable Manual Gain
42 74 A3 ; Channel A Gain = 250
42 75 E8 ; Channel B Gain = 250
42 76 FA ; Channel C Gain = 250
42 7B 06 ; Spread AV Code over Channels A & B, Clamped and Gained Data during H\V Blanking
         ; Channels A, B & C = 64 NOT SET for YPrPb I/Ps
42 85 19 ; Force SOG Sync Selection, Output Synchronous V Syncs
42 86 0B ; Enable stdi_line_count_mode
42 8A 10 ; Automatic VCO_RANGE Selection
42 8F 07 ; Automatic LLC1 Output Selection
42 90 29 ; FR_LL Decoded from PRIM_MODE and VID_STD
42 BF 02 ; Output Default Colour when Missing Video (Not Required ?!)
42 C5 01 ; CP_CLAMP_AVG_FACTOR[1-0] = 00b
42 F3 07 ; Enable Anti Alias Filters on ADC Channels 0, 1 & 2
42 0E 80 ; ADI Recommended Setting
42 52 46 ; ADI Recommended Setting
42 54 00 ; ADI Recommended Setting
42 F6 3B ; ADI Recommended Setting
42 0E 00 ; ADI Recommended Setting
Any help would be greatly appreciated.
Regards, Rob.
