Can not enter timer interrupt wihout debug mode
Question asked by danielc@nexsens.com on Feb 6, 2013
Latest reply on Mar 13, 2013 by AudeR
Below is my code, I want use two timers, timer1 for 0.315ms and timer0 for 40s. And timer0 has higher priority than timer1. When I use IAR compiler to debug it by a USB-SWD/UART board, it works fine. But when I just power the board through DVDD and GND pins using two AA batteries. It can not enter timer0.
Thank you.
unsigned int uiSleepTimer = 0;
unsigned int uiHibernateTimer= 0;
unsigned char ucGoToSleep = 0;
unsigned char ucGoToHibernate = 0;
//////// Init Part////////////
static void Timer0Init(void);
static void Timer1Init(void);
static void delay(unsigned long);
void main()
    pADI_WDT ->T3CON = 0;   // Disable watchdog
    DioOen(pADI_GP1,0x38); // Set P1.3 as an output for test purposes
    WdtCfg(T3CON_PRE_DIV1,T3CON_IRQ_EN,T3CON_PD_DIS);
    ClkDis(CLKDIS_DISSPI0CLK|CLKDIS_DISSPI1CLK|CLKDIS_DISPWMCLK|CLKDIS_DISDMACLK);
    ClkCfg(CLK_CD3,CLK_HF,CLKSYSDIV_DIV2EN,CLK_UCLKCG);        // Choose 2MHz for CUP clock
    ClkSel(CLK_CD6,CLK_CD0,CLK_CD0,CLK_CD0);                      // Select CD0 for UART System clock, also for I2C
    NVIC_SetPriority(TIMER0_IRQn,1);
    NVIC_SetPriority(TIMER1_IRQn,2);
    Timer0Init();
    NVIC_EnableIRQ(TIMER0_IRQn);        // Enable Timer1 IRQ
    Timer1Init();
    NVIC_EnableIRQ(TIMER1_IRQn);        // Enable Timer1 IRQ
    while(1)
        if(uiHibernateTimer == 1)
            DioSet(pADI_GP1,0x8);
        else
            DioTgl(pADI_GP1,0x8);
            delay(0x10000);
    GptLd(pADI_TM0,40);                                  // Set timeout period for 60 seconds
    GptCfg(pADI_TM0,TCON_CLK_LFOSC,TCON_PRE_DIV32768,TCON_MOD_PERIODIC|TCON_RLD|TCON_ENABLE);
*    Initialize the timer1
    GptLd(pADI_TM1,0xFFFE);                //Set timeout period for 0.315ms
    GptCfg(pADI_TM1,TCON_CLK_LFOSC,TCON_PRE_DIV16,TCON_MOD_PERIODIC|TCON_UP|TCON_RLD|TCON_ENABLE);
* A simple delay function
void delay (unsigned long length)
   while (length >0)
      length--;
//                          Interupt Handler                                  //
void GP_Tmr0_Int_Handler(void)
    pADI_TM0->CLRI = 0x01;    // Clear T0 interrupt
    while( (pADI_TM0->STA & 0x01) == 0x01)
    uiHibernateTimer = 1;
void GP_Tmr1_Int_Handler(void)
    pADI_TM1->CLRI = 0x01;      // Clear T1 interrupt
    while( (pADI_TM1->STA & 0x01) == 0x01)
    uiSleepTimer++;
    if(uiSleepTimer > 15780)
        uiSleepTimer = 0;
        delay(0x3000);
        DioClr(pADI_GP1,0x8);
