ADV7604 Register setting
Question asked by SteveChen on Feb 5, 2013
Latest reply on Mar 19, 2013 by joe.triggs
Currently we are using ADV7604 with TI's DM365 for a VGA video recording purpose. Our DM365 side is expecting a YUV 4:2:2 16-bit separate sync video input. I've follow the "ADV7604-output-pixel-port-mapping-revH.XLS" by mapping (setting OP_FORMAT_SEL to 80) P16~P23 to Y input of DM365 and P4~P11 to CbCr input of DM365. We hook up a laptop VGA output to ADV7604 AIN7, 8, 9 and sync 3 as the Eval board did. However the raw data we captured from DM365 show that the input color (output from ADV7604) is all wrong. If I input Green , it will show a darker green. If I input blue, it will show purple-ish. If I input red, it will show white-greyish color. Please help if you see problems with my configuration setup. Thank you!
We have used the recommended register setting from the ADI Eval board script as follow:
##Graphics - XGA, 1024x768##
:Graphics-3.1 1024x768 _@ 60 65.000MHz Out through DAC:
40 0C 42 ; Power up part and Power down VDP
40 00 0C ; VID_STD=01100b for 1024x768 _@ 60
40 01 82 ; Enable Simultaneous Mode ,Prim_Mode =0010b for GR
40 02 F2 ; Auto CSC , RGB Out
40 03 42 ; 36 Bit SDR
40 05 28 ; TURN OFF EAV & SAV CODES & Enable Freerun
40 0B 44 ; Power down ESDP block
40 14 7F ; Drive strength adjustment
40 15 90 ; Disable Tristate of Pins except for Audio pins
40 33 60 ; LLC DLL Mux Enable
44 3E 04 ; Enable gain control for CP
44 40 5C ; Adjust CP gain for PGA gain of 1.4
44 69 30 ; Enable CP CSC
44 85 0B ; Disable Autodetectmode for Sync_Source for CH1. Force CH1 to use seperate HS & VS.
44 C3 39 ; ADI recommended write
44 CF 01 ; Power off macrovision
4C 13 93 ; Set LLC DLL Phase
4C 02 02 ; Ain_Sel to 010. (Ain 7,8,9)
4C 05 07 ; AA filter Enable
4C 06 20 ; Set AA_filt_high_BW to 11
4C 07 A0 ; Set AA_filt_high_BW to 11 & aa_filt_prog_bw to 01
4C 12 63 ; Turn Noise shaping OFF
4C 0C 1F ; Set PGA gain to 1.4
4C C6 5F ; Disable Audio Core
50 10 00 ; Mux
End
