AD9726 clocks
Question asked by jharris on Feb 4, 2013
Latest reply on Feb 4, 2013 by larrywelchusa
I am planning on using the AD9726 for a design since it seems to provide the lowest noise performance of an DAC that needs to run at 40MHz (seems like if I need to run at over 10MHz, I need to use a part that is capable of running at a lot more than 40MHz).
I am also planning to use 2 AD9726 in parallel for two data streams that need to have the same delay.  Therefore, I was going to bypass the data sync mode.
The datasheet has conflicting information, so I wanted to know what to do with the clocks when I use it in this mode:
CLK+/-
DCLK_IN+/-
DCLK_OUT+/-
I know that in this mode CLK+/- is used to clock the data, so do I leave DCLK_IN and OUT unconnected (and do I ground DCLK_IN)?  And then I have a clock chip provide a CLK+/- to the FPGA (feeds AD9726) and AD9726?
Thank you
