What is the fastest way to change freq. & off freq.(in AD9910)
Question asked by JongWon on Feb 4, 2013
Latest reply on Feb 5, 2013 by KennyG
Hello. I'm using AD9910.
My routine is,
(1) Initializing Register & setting Amplitude by serial pins.
(2) Setting freq. by parallel pins.
Setting freq. routine is following,
   TxEN = 1;     //Enable TxENABLE pin High
   F1 = 1;          //
   F0 = 0;          //F1 & F0 is parallel port destination pins
   P1 = 0x12;     //
   P0 = 0x34;     //P1 & P0 is GPIO in CPU, & it is connected to D0~D15 directly.
   TxEN = 0;     //TxENABLE pin Low
by that code, I can set freq. I think setting freq. is fast enough.
Now I want to DDS output off the fastest way.
Please give me some advice.
following is my thinking. but my poor english skill, you may have problem to understand it. So just view references.
(1) Use profile.
I think, If I put Amplitude 0, freq. 0hz data to single tone profile, then If I select that profile,
DDS output may 0.
But, to use this way, Some Registers should be changed.(parallel mode -> single tone mode)
(2)
   F1 = 0;          //
   P1 = any value;     //
   P0 = any value;     //P1 & P0 is GPIO in CPU, & it is connected to D0~D15 directly.
(Since AD9910 parallel mode doesn't have memory) After setting freq., If I change F1 & F0, then output may go to zero.
But I can not sure this way is good.
(3) Use only single tone profile.
First, put data single tone profile0.
Next, put zero data(Amp. 0, freq. 0 hz) to single tone profile1
If I only change profile0 to 1, or 1 to 0,
I can set freq. and off freq.
Please give me some advice and recommend the fastest way.
Thank you.
