UART and DMA on BF504
Question asked by grzegorz on Feb 2, 2013
Latest reply on Feb 5, 2013 by grzegorz
Hello.
I try to send data using UART1 and DMA on BF504. I have following code:
void configureUART() {
    *pPORTF_FER |= PF6 | PF7; //enable UART1 pins
    *pUART1_GCTL = UCEN; //enable UART clocks
    *pUART1_LCR = WLS(8); //8 data bits
    *pUART1_DLL = 1;
    *pDMA10_CONFIG = WNR | WDSIZE_16 | FLOW_AUTO; //UART1 RX, memory write, 16-bit, autobufer mode
    *pDMA10_START_ADDR = i2s_buf_out;  /* start address of data buffer */
    *pDMA10_X_COUNT = MAX_SAMPLES;     /* DMA loop count */
    *pDMA10_X_MODIFY = 4; /* DMA loop address increment */
    *pDMA11_CONFIG = WDSIZE_16 | SYNC | FLOW_AUTO; /* UART1 TX, memory read, 16-bit transfers, autobuffer mode */
    *pDMA11_START_ADDR = i2s_buf_in; /* start address of data buffer */
    *pDMA11_X_COUNT = MAX_SAMPLES;
    *pDMA11_X_MODIFY = 4; /* DMA loop address increment */
    *pDMA10_CONFIG |= DMAEN; /* enable DMA for RX */
    *pDMA11_CONFIG |= DMAEN; /* enable DMA for TX */
Unfortunately it doesn't work, the UART1_TX pins remains in high state, not data are transmitted. Expect the contents of i2s_buf_in to be continously transmitted, but nothing is happening. Am I missing something?
