AD9467_FMC_250_EBZ + VC707 sample rates
Question asked by curry@bridgerphotonics.com on Jan 29, 2013
Latest reply on Jan 31, 2013 by curry@bridgerphotonics.com
I just started using the AD9467_FMC_250_EBZ board with the VC707. I have followed the instructions at http://wiki.analog.com/resources/fpga/xilinx/fmc/ad9467 and everything is working as expected, provided I drive my ADC clock at 240-250MHz. The software finds the zero-error delay setting and the data look clean in ChipScope.
Any slower than 240MHz and I get the error:
"adc_setup: can not set a zero error delay!",
and I get corrupted data in ChipScope. Because the instructions say "The clocks must be running on the FMC board before FPGA is programmed.", I am reprogramming the FPGA each time I change frequencies. I was previously running the reference design on the ML605 and I was able to run from 250MHz all the way down to 50MHz.
Does anybody have insight into what might be causing this problem? Thank you!
Jim
