How to use the the bf548 PATA interface to configure CF card ?
Question asked by qian on Jan 27, 2013
Latest reply on Jan 27, 2013 by qian
     I use the board PATA interface to connect the CF card , CF card work in TRUE-IDE mode .
    uClinux version:blackfin-linux-dist-2011R1-RC3.tar
Schematics are as follows:
The kernel configuration is as follows :
Board-level configuration:
Kernel boot does not detect the CF card .
The error message is as follows :
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   bf548-0.2-3.0.8-ADI-2011R1
   Created:      2013-01-27   7:21:22 UTC
   Image Type:   Blackfin Linux Kernel Image (gzip compressed)
   Data Size:    5425206 Bytes = 5.2 MiB
   Load Address: 00001000
   Entry Point:  0025fe68
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting Kernel at = 0025fe68
Linux version 3.0.8-ADI-2011R1 (cornelius@cornelius-linux) (gcc version 4.3.5 (ADI-2011R1-RC4) ) #9 Sun Jan 27 15:21:01 CST 2013
register early platform devices
bootconsole [early_shadow0] enabled
bootconsole [early_BFuart1] enabled
early printk enabled on early_BFuart1
Board Memory: 64MB
Kernel Managed Memory: 64MB
Memory map:
  fixedcode = 0x00000400-0x00000490
  text      = 0x00001000-0x0019a280
  rodata    = 0x0019a280-0x00227598
  bss       = 0x00228000-0x00239d3c
  data      = 0x00239d3c-0x00256000
    stack   = 0x00254000-0x00256000
  init      = 0x00256000-0x00a0b000
  available = 0x00a0b000-0x03e00000
  DMA Zone  = 0x03e00000-0x04000000
Hardware Trace active and enabled
Boot Mode: 1
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF548 Rev 0.2
Warning: Compiled for Rev 2, but running on Rev 4
Warning: Unsupported Chip Revision ADSP-BF548 Rev 0.4 detected
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 525 MHz core clock and 131 MHz System Clock
NOMPU: setting up cplb tables
Instruction Cache Enabled for CPU0
  External memory: cacheable in instruction cache
  L2 SRAM        : uncacheable in instruction cache
Data Cache Enabled for CPU0
  External memory: cacheable (write-through) in data cache
  L2 SRAM        : uncacheable in data cache
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 15748
Kernel command line: root=/dev/mtdblock0 rw clkin_hz=25000000 earlyprintk=serial,uart1,57600 console=tty0 console=ttyBF1,57600
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory available: 52596k/65536k RAM, (7892k init code, 1636k kernel code, 752k data, 2048k dma, 612k reserved)
NR_IRQS:295
Configuring Blackfin Priority Driven Interrupts
Console: colour dummy device 80x25
console [tty0] enabled
console [ttyBF1] enabled, bootconsole disabled
Calibrating delay loop... 1044.48 BogoMIPS (lpj=2088960)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (16 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 48 KB (41 KB free)
Blackfin L2 SRAM: 128 KB (128 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
ezkit_init(): registering device resources
bio: create slab <bio-0> at 0
SCSI subsystem initialized
spi spi0.2: Warning: SPI CPHA not set: Slave Select not under software control!
See Documentation/blackfin/bfin-spi-notes.txt
bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 1.0, regs@ffc00500, dma channel@4
bfin-spi bfin-spi.1: Blackfin on-chip SPI Controller Driver, Version 1.0, regs@ffc02300, dma channel@5
i2c-bfin-twi i2c-bfin-twi.0: Blackfin BF5xx on-chip I2C TWI Contoller, regs_base@ffc00700
i2c-bfin-twi i2c-bfin-twi.1: Blackfin BF5xx on-chip I2C TWI Contoller, regs_base@ffc02200
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
debug-mmrs: setting up Blackfin MMR debugfs
msgmni has been set to 102
io scheduler noop registered (default)
bfin-uart: Blackfin serial driver
bfin-uart.1: ttyBF1 at MMIO 0xffc02000 (irq = 48) is a BFIN-UART
bfin-otp: initialized
brd: module loaded
register bfin atapi driver
pata-bf54x pata-bf54x: Fail to reset ATAPI device
pata-bf54x: probe of pata-bf54x failed with error -14
physmap platform flash device: 02000000 at 20000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000089 Chip ID 0x00881e
Intel/Sharp Extended Query Table at 0x010A
Using buffer write method
Using auto-unlock on power-up/resume
cfi_cmdset_0001: Erase suspend on write enabled
Using physmap partition information
Creating 5 MTD partitions on "physmap-flash.0":
0x000000000000-0x000000080000 : "bootloader(nor)"
0x000000080000-0x000000480000 : "linux kernel(nor)"
0x000000480000-0x000000fe0000 : "file system(nor)"
0x000000fe0000-0x000000ff8000 : "config(nor)"
0x000000ff8000-0x000001000000 : "u-boot env(nor)"
m25p80 spi0.1: unrecognized JEDEC id ffffff
smsc911x: Driver version 2008-10-21
input: bf54x-keys as /devices/platform/bf54x-keys/input/input0
rtc-bfin rtc-bfin: rtc core: registered rtc-bfin as rtc0
i2c /dev entries driver
bfin-wdt: initialized: timeout=20 sec (nowayout=0)
dma_alloc_init: dma_page @ 0x02b09000 - 512 pages at 0x03e00000
TCP cubic registered
rtc-bfin rtc-bfin: setting system clock to 1970-05-07 12:14:56 UTC (10930496)
Freeing unused kernel memory: 7892k freed
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new SD card at address 0002
                           _____________________________________
        a8888b.           / Welcome to the uClinux distribution \
       d888888b.         /       _     _                         \
       8P"YP"Y88        /       | |   |_|            __  __ (TM)  |
       8|o||o|88  _____/        | |    _ ____  _   _ \ \/ /       |
       8'    .88       \        | |   | |  _ \| | | | \  /        |
       8`._.' Y8.       \       | |__ | | | | | |_| | /  \        |
      d/      `8b.       \      \____||_|_| |_|\____|/_/\_\       |
     dP   .    Y8b.       \   For embedded processors including   |
    d8:'  "  `::88b        \    the Analog Devices Blackfin      /
   d8"         'Y88b        \___________________________________/
  :8P    '      :888
   8a.   :     _a88P         For further information, check out:
._/"Yaa_:   .| 88P|            - http://blackfin.uclinux.org/
\    YP"    `| 8P  `.          - http://docs.blackfin.uclinux.org/
/     \.___.d|    .'           - http://www.uclinux.org/
`--..__)8888P`._.'  jgs/a:f    - http://www.analog.com/blackfin
Have a lot of fun...
BusyBox v1.18.4 (2013-01-24 23:58:47 CST) hush - the humble shell
root:/>
I only found in "http://docs.blackfin.uclinux.org/doku.php?id=linux-kernel:drivers:pata_platform" the bf537 configuration , availability bf548 kernel configuration ?
Thank you.
