TWI Driver Sends Only 1 Byte
Question asked by spflanze on Jan 25, 2013
Latest reply on Feb 7, 2013 by SachinV
In the below code snippets I need three bytes of the buffer DataBufferOutbound to be sent on the TWI bus. I can see on the scope only one byte is being sent, and its value is 1. The values in DataBufferOutbound are ignored. I need to know what is wrong.
The below code is a representation of the sequence the relevant statements are executed in. Irrelevant code is excluded:
// 3 bytes are needed to write a command ( 1 for address plus 2 for data)
// 2 bytes are needed to read data.
// Both of these are sized to 4 to align on 32 bit boundaries:
static unsigned char DataBufferOutbound[4];
static unsigned char DataBufferInbound[4];
// The Buffers Instantiated:
// One is required for sending a command and two are required to query.
static ADI_DEV_SEQ_1D_BUFFER pot_SeqBuffer[2];
const adi_twi_bit_rate pot_bit_rate = { .frequency = 100, .duty_cycle = 50 };
ADI_DEV_CMD_VALUE_PAIR TWIConfig[] = {
    { ADI_TWI_CMD_SET_HARDWARE,                (void *)ADI_INT_TWI1 }, // select a hardware TWI port (pass ADI_INT_PERIPHERAL_ID of hardware)
    { ADI_DEV_CMD_SET_DATAFLOW_METHOD,    (void *)ADI_DEV_MODE_SEQ_CHAINED},
    { ADI_TWI_CMD_SET_FIFO,                      (void *)0x0000 }, // set FIFO interrupt levels
    { ADI_TWI_CMD_SET_RATE,                        (void *)&pot_bit_rate }, // select the frequency and duty cycle (pass adi_twi_bit_rate struct)
    { ADI_TWI_CMD_SET_LOSTARB,              (void *)1 }, // set number of retries before reporting LOSTARB
    { ADI_TWI_CMD_SET_ANAK,                      (void *)10 }, // set number of retries before reporting ANAK
    { ADI_TWI_CMD_SET_DNAK,                      (void *)10 }, // set number of retries before reporting DNAK
    { ADI_DEV_CMD_SET_DATAFLOW,                (void *)TRUE },
    { ADI_DEV_CMD_END,                    NULL } // Terminator element
u32 Init(void){
     twi1_Init_result = adi_dev_Open(
                adi_dev_ManagerHandle,
                &ADITWIEntryPoint,
                1,  // TWI Device Number
                NULL, // Client Handle ( passed to call back function )
                &twi1_DeviceHandle,
                ADI_DEV_DIRECTION_BIDIRECTIONAL,
                NULL, // DMA Handle (TWI has no DMA)
                adi_dcb_QueueHandle, //Handle to the deferred callback service deferred.
                twi1_ClientCallback // Call Back Function.
      // Set values in the chain's outbound buffer element:
      pot_SeqBuffer[0].Buffer.Data            = (void *)DataBufferOutbound;
      // Set to 3 for commands, and 2 for queries
      pot_SeqBuffer[0].Buffer.ElementCount   = 3;
      pot_SeqBuffer[0].Buffer.ElementWidth   = 1;
      pot_SeqBuffer[0].Buffer.CallbackParameter = (void *) 1;    // no callback
      // Set to NULL for commands, set to (ADI_DEV_1D_BUFFER *)&pot_SeqBuffer[1]
      // for queries.
      pot_SeqBuffer[0].Buffer.pNext = (ADI_DEV_1D_BUFFER *)&pot_SeqBuffer[1];
      pot_SeqBuffer[0].Buffer.pAdditionalInfo = (void*)NULL;
      pot_SeqBuffer[0].Direction = ADI_DEV_DIRECTION_OUTBOUND;
      // Set values in the chain's inbound buffer element:
      pot_SeqBuffer[1].Buffer.Data     = (void *)DataBufferInbound;
      pot_SeqBuffer[1].Buffer.ElementCount = 2;
      pot_SeqBuffer[1].Buffer.ElementWidth = 1;
      pot_SeqBuffer[1].Buffer.CallbackParameter = (void *) 2;
      pot_SeqBuffer[1].Buffer.pNext = (void *)NULL;     // end of chain
      pot_SeqBuffer[1].Buffer.pAdditionalInfo = (void*)NULL;
      pot_SeqBuffer[1].Direction = ADI_DEV_DIRECTION_INBOUND;
     adi_dev_Control(twi1_DeviceHandle, ADI_DEV_CMD_TABLE, (void*)TWIConfig))
      // Set up test values to see on the oscilloscope:
      int i;
      for( i=0; i<3; i++ ){
       DataBufferOutbound[i] = 0xAA;
   // Configure buffer for command send:
   pot_SeqBuffer[1].Buffer.ElementCount = 3;
   pot_SeqBuffer[0].Buffer.pNext = (void*)NULL;
   // This function call sends only one byte instead of the expected three, and only that byte's least significant bit is set:
   Result = adi_dev_SequentialIO(twi1_DeviceHandle, ADI_DEV_SEQ_1D, (ADI_DEV_BUFFER *)pot_SeqBuffer);
