AD9912 SPI on Atmel AVR
Question asked by divyansh on Jan 18, 2013
Latest reply on Jan 24, 2013 by LouijieC
I have been trying to set a SPI for AD9912 but , I have failed to do so.I have used AD9912 previously but using bit banging not through any digital bus.Now ,I need to transfer data to see a sweep pattern at 10 hz having at least 100 points.I have read a similar post on PIC  but I am unable to get this through.Is it so that the SPI of AD9912 is not a standard one ??
What is the best way to send frequency very quickly through its Serial Interface ?
  • Improvised routine on Two wire interface. ? (Not Tried)
  • Sending bits in streams of data - done but takes time
  • Sending data on SPI bus in mode 0 - not working
I have written following function in Codevision/AVR studio  AVR for ATmega32A using SPI library at spi-on-an-avr
extern void spi(char data);
//Transfers data to MOSI
//SPI mode(0) - Sample(rising) / Setup(falling)
void write_byte(unsigned char data,unsigned int addr)
int i;
unsigned char temp_addr=((addr&0x1f00)>>8);
CSB_LOW;
spi(temp_addr); //MSB
pi(addr&0x00ff);//LSB
pi(data);//DATA
CSB_HI;
toggle_io(); //0-1-0
Connections
SDIO ~ MOSI
SCK ~ SCK
CSB ~ (SS!)
SDO - not connected
It can be done another part number, but I think its possible using this part number only.If I am missing any part that you think is important kindly let me know.
Thanks and Regards,
Divyansh gupta
www.aet-embedtech.com
