Timer sync problem (BF537)
Question asked by carber on Jan 10, 2013
I'm having trouble getting TIMER3 to assert on the rising edge of PPI_CLK when also using PPI.
In the HRM it says: The TMRx pin transitions on rising edges of PWM_CLK. There is no way to select the falling edges of PWM_CLK.
PPI_CLK = TMRCLK = DOTCLK
I'm using 3 sync signals (FS3 is not used) and everything is clocked with PPI_CLK:
HSYNC -> FS1
VSYNC -> FS2
ENABLE -> TIMER3
TIMER3 configuration:
set_gptimer_period(TIMER_ENABLE_id, fbi->h_period);
set_gptimer_pwidth(TIMER_ENABLE_id, fbi->h_actpix);
set_gptimer_config(TIMER_ENABLE_id, TIMER_MODE_PWM | TIMER_PERIOD_CNT |
           TIMER_TIN_SEL | TIMER_CLK_SEL |
           TIMER_EMU_RUN);
FS1 and FS2 timer configurations:
set_gptimer_period(TIMER_HSYNC_id, fbi->h_period);
set_gptimer_pwidth(TIMER_HSYNC_id, fbi->h_pulse);
set_gptimer_config(TIMER_HSYNC_id, TIMER_MODE_PWM | TIMER_PERIOD_CNT |
           TIMER_EMU_RUN);
set_gptimer_period(TIMER_VSYNC_id, fbi->v_period);
set_gptimer_pwidth(TIMER_VSYNC_id, fbi->v_pulse);
set_gptimer_config(TIMER_VSYNC_id, TIMER_MODE_PWM | TIMER_PERIOD_CNT |
               TIMER_EMU_RUN);
I have tried 4 PPI configurations, 2 of them have this problem:
#1
bfin_write_PPI_DELAY(fbi->h_start);
bfin_write_PPI_COUNT(fbi->h_actpix - PPI_COUNT_CORR_OFFSET);
bfin_write_PPI_FRAME(fbi->v_lines);
bfin_write_PPI_CONTROL(PPI_TX_MODE |
        PPI_XFER_TYPE_11 |
        PPI_PORT_CFG_01 |
        DLEN_16);
FS1 and FS2 are asserted on falling edge (should be rising).
Data is driven on falling edge (OK!).
TIMER3 is asserted on rising edge (OK!).
#2
        PPI_XFER_TYPE_11 |
        PPI_PORT_CFG_01 |
        DLEN_16 |
        PPI_POLS_1);
FS1 and FS2 are asserted on falling edge (OK!).
#3
        PPI_XFER_TYPE_11 |
        PPI_PORT_CFG_01 |
        DLEN_16 |
        PPI_POLC_1);
FS1 and FS2 are asserted on rising edge (OK!).
Data is driven on rising edge (OK!).
TIMER3 is asserted on falling edge (should be rising).
#4
        PPI_XFER_TYPE_11 |
        PPI_PORT_CFG_01 |
        DLEN_16 |
        PPI_POLC_1 |
        PPI_POLS_1);
FS1 and FS2 are asserted on rising edge (should be falling).
Here is a block diagram of the HW:
