ADSP-21489 SPI Flash can not work
Question asked by Guillaume on Jan 7, 2013
Latest reply on Jan 8, 2013 by Guillaume
my custom board use ADSP-21489 and I want to run a simple LED program to test SPI Flash "M25P80".
The program TOGGLE a LED through DPI-07 output.
main()
  Init_PLL();
  Init_LEDs();
  interrupts (SIG_TMZ, timer_isr); // enable high priority timer interrupt
  timer_set(2e8, 1e4); // 2Hz timer interrup (abt 2e8/4e8=0.5s=500ms)
  timer_on(); // start timer
  while(1)
        if (core_time_flag == 1)
            core_time_flag = 0;
            timer_count++;
            ClearSet_LED(LED_TOGGLE & 0x1);
            LED_TOGGLE ++;
void Init_LEDs(void)
    /* setting the SRU and route so that flag pins connect to DPI pin buffers */
    /*connect Flag6 output to DPI_PB07 input (LED) */
    SRU(FLAG6_O,DPI_PB07_I); /* connect Flag6 output to DPI_PB08 input (LED) */
    /*enabling the buffer using the following sequence: high -> output, low ->input */
    SRU(HIGH,DPI_PBEN07_I); /* LED */
    /*setting flag pins as outputs */
    sysreg_bit_set( sysreg_FLAGS, (FLG6O) );
    /*clearing flag pins */
    sysreg_bit_clr( sysreg_FLAGS, (FLG6) );
void ClearSet_LED(const char State)
    /* if State is 0 (LED_OFF) we clear the LED,
    if State is 1 (LED_ON) we set the LED,
    else we toggle the LED */
    if(LED_OFF == State ) { sysreg_bit_clr(sysreg_FLAGS, FLG6); }
    else if( LED_ON == State ) { sysreg_bit_set(sysreg_FLAGS, FLG6); }
void timer_isr (int sig)
     core_time_flag = 1;
I can run the executable file of the above program successfully under debug mode. I generate a loader file (Boot type: SPI flash, format:Hex, Width:8-bit) and modify flash driver based on that of M25P16, which is provided by VDSP++5. I only make two changes for the driver,
  1. //#define NUM_SECTORS 32 /* number of sectors in m25p16 flash device */
     #define NUM_SECTORS 16 /* number of sectors in m25p80 flash device */
  2. repace all the string m25p16 with m25p80
The driver was tested ok using another custom board before.
I can success download the programs to SPI flash. However, when I pull-off the JTAG connector and re-power on the board, the LED
has no blink. Measurement shows that the DPI-07 has a stable 1.55V output,
The board set BOOT_CFG0~2 pins [1 0 0].
Hope to get your help to tell me what's wrong with my SPI flash reboot.
Thanks
