ADT7310 interfacing with PIC
Question asked by mnanand1988 on Jan 3, 2013
Latest reply on Jan 5, 2013 by mnanand1988
i am using adt7310 with PIC microcontroller.
I am trying to read the temperature register value in continuous mode. In the beginning I am resetting the sensor by sending more than 32 ones to the DIN of ADT7310. After that I am reading the ID, but I am getting all zero. then I am writing 0x80 to the configuration register and sending the command 0x54 for getting the temperature value continuously. I am getting some gunk values or all zeros (0x0000). it is not matching with the temperature.
This is the code that I am using. Please help me to get the values correctly.
#include <p18f25k80.h>
#include<math.h>
#include<Delays.h>
#include<spi.h>
#pragma config WDTEN=OFF, FOSC=HS2, FCMEN=ON, IESO=OFF, XINST=OFF
#define SPI_CS PORTCbits.RC2
#define SPI_CK PORTCbits.RC3
#define SPI_DO PORTCbits.RC5
#define SPI_DI PORTCbits.RC4
void adt_init();
void adt_temp();
void resetadt();
void usart1_init();
void usart1_send(int);
void float_char(char,float, int);
void newline();
double adt_tval;
long int adt_th,adt_tl, adt_sgn,adt_t;
char Temp_adt[2],sgn_adt = '+',data[16],ID;
int val[] = {'0','1','2','3','4','5','6','7','8','9'},i;
/////////////////////////usart functions///////////////////
void usart1_init()
          SPBRG1 = 0X81;
          SPBRGH1 = 0X00;
          TXSTA1 = 0b00000010;
          RCSTA1 = 0b10110000;
          BAUDCON1 = 0b01001000;
void newline()
          TXSTA1bits.TXEN = 1;
          TXREG1 = '\n';
          while(!TXSTA1bits.TRMT);
TXSTA1bits.TXEN = 0;
void float_char(char h,float l,int k)
          long int m,n,o,g;
          m = l*1000;
          n = m%1000;
          m = m/1000;
data[0] = h;
for(k--,i = 1;k>=0;k--,i++)
o = pow(10,k);
g = m/o;
m = m%o;
data[i] = val[g];
data[i] =  '.';
for(k = 2,i++;k>=0;k--,i++)
          o = pow(10,k);
          g = n/o;
            n = n%o;
data[i] = val[g];
void usart1_send(int a)
for(i=0;i<a;i++)
          TXREG1 = data[i];
          TXREG1 = '\t';
          TXREG1 = '\t';
/////////////////////////////////Delay fuctions///////////////////
//1 ms delay 6250cycles=1ms
void msdelay(unsigned int num)
    unsigned int i;
    for(i=1;i<=num;i++)
        Delay1KTCYx(6);
        Delay10TCYx(25);
//.1 ms delay
void mssdelay(unsigned int num)
    unsigned int j;
    for(j=1;j<=num;j++)
        Delay10TCYx(62);
        Delay1TCY();
        Delay1TCY();
        Delay1TCY();
        Delay1TCY();
        Delay1TCY();
//.01 ms delay
void msssdelay(unsigned int num)
    unsigned int k;
    for(k=1;k<=num;k++)
        Delay10TCYx(6);
        Delay1TCY();
        Delay1TCY();
void DelayFor18TCY(void)
Nop( ); Nop( ); Nop( ); Nop( ); // 18 cycle delay
Nop( ); Nop( );
return;
////////////////////////////ADT7310 functions///////////////////////
void adt_temp()
//adt_th = Temp_adt[0];
//adt_tl = Temp_adt[1];
adt_sgn = adt_th & 0x80;
adt_t = (adt_th*256)+adt_tl;
//adt_t = adt_t>>3;
if(adt_sgn == 0x80)
sgn_adt = '-';
adt_tval = adt_t - 65536;
adt_tval = adt_tval/128;
else
sgn_adt = '+';
adt_tval = adt_t/128;
void adt_init()
SPI_CS = 0;
putcSPI(0x08);
putcSPI(0x80);
SPI_CS = 1;
msdelay(1000);
void resetadt()
unsigned int i;
SPI_CS=0;/*
SPI_DO=1;
for(i=0;i<100;i++)
SPI_CK=0;
mssdelay(1);
SPI_CK=1;
mssdelay(1);
SPI_DO=0;
//putcSPI(0x54);*/
putcSPI(0xFF);
putcSPI(0xFF);
putcSPI(0xFF);
putcSPI(0xFF);
SPI_CS=1;
//////////////////////////////////Main function///////////////////////
void main()
TRISCbits.TRISC6 = 0;
TRISCbits.TRISC7 = 1;
TRISCbits.TRISC2= 0;   // RB2/CS - Output (Chip select)
TRISCbits.TRISC3= 0;   // RC3/SCK - Output (Clock)
TRISCbits.TRISC4= 1;   // RC4/SDI - Input (Serial Data In)
TRISCbits.TRISC5= 0;   // RC7/SDO - Output (Serial Data Out)
ADCON1=0x0F;
          usart1_init();
OpenSPI(SPI_FOSC_64, MODE_10,SMPMID);
while(1)
//SPI_CS = 1;
//msdelay(1000);
resetadt();
SPI_CS = 0;
putcSPI(0x58);
SPI_CS = 1;
msdelay(1);
SPI_CS = 0;
ID = ReadSPI();
SPI_CS = 1;
adt_init();
SPI_CS= 0;
putcSPI(0x54);
msdelay(1);
SPI_CS = 1;
msdelay(2000);
SPI_CS = 0;
//while(SSPSTATbits.BF == 0);
adt_th = ReadSPI();
adt_tl = ReadSPI();
msdelay(1);
adt_temp();
if(adt_tval == 0)
resetadt();
adt_init();
//if(adt_tval != 0)
float_char(' ',adt_th,5);
usart1_send(i);
float_char(' ',adt_tl,5);
usart1_send(i);
float_char(' ',adt_t,5);
usart1_send(i);
float_char(' ',adt_tval,3);
usart1_send(i);
float_char(' ',ID,3);
usart1_send(i);
newline();
msdelay(2000);
resetadt();
