Sharc 21489 accelerator implementation
Question asked by constant-q on Dec 27, 2012
Latest reply on Jan 3, 2013 by Harshit.Gaharwar
Dear all
I encounter problems when trying to add the EE322-generated FIR (or IIR) accelerator code to the example "21489 AD1939 C Block-Based Talkthru 48 or 96 kHz". When initializing the array for the TCBs, the compiler produces the following errors:
----------------Configuration: 21489 AD1939 C Block-Based Talkthru 48 or 96 kHz - ReleaseNWC----------------
.\blockProcess_audio.c
".\blockProcess_audio.c", line 262: cc1080: {D} warning: Function does not
          have a full prototype
  Init_FIR();
.\FIR_Accelerator.C
".\FIR_Accelerator.C", line 19: cc0144: {D} warning: a value of type "int *"
          cannot be used to initialize an entity of type "int"
  FIR_CF_buff1,
(...some lines omitted...)
".\FIR_Accelerator.C", line 39: cc0513: {D} warning: a value of type "int *"
          cannot be assigned to an entity of type "int"
  FIR_TCB_CH1[0]=FIR_TCB_CH1+12;
".\FIR_Accelerator.C", line 57: cc0513: {D} warning: a value of type "int *"
          cannot be assigned to an entity of type "unsigned int"
  *pCPFIR=FIR_TCB_CH1+12-0x80000;
Nevertheless, the compiler doesn't stop.
I tryed a few things, but nothing helped...
The code is as produced by the FIR Accelerator plugin. The same issue showed also up when adding the IIR routines...
/* Declaring the external buffers needed for FIR Accelerator*/
extern int FIR_IP_buff1[];
extern int FIR_OP_buff1[];
extern int FIR_CF_buff1[];
/*Adding the TCB for FIR channels*/
int FIR_TCB_CH1[13]={
                0,
                256,
                1,
                FIR_CF_buff1,
                FIR_OP_buff1,
                256,
                1,
                FIR_OP_buff1+0,
                FIR_IP_buff1,
                512,
                1,
                FIR_IP_buff1+0,
                255|(255<<14)
The ADI published IIR accelerator example code looks quite the same and works perfect.
Does anyone have an idea how to fix this?
Thanks a lot Chris
