Setting DAC output on aduc842.
Question asked by Marcomartinelli1 on Dec 21, 2012
Latest reply on Dec 22, 2012 by Marcomartinelli1
Hello.
I have some problems regarding the set of the dacs output on a aduc842.
I clear the output at the start part of the program and after I cannot set
anymore the outputs of the dacs.
Should I disable the interrupts during the writing on the dacs sfr ?
Is the procedure below correct?
SETUP:
      ;SETUP UART FOR ADUC 842
      MOV    T3CON,#083H
      MOV    T3FD,#02DH
       MOV     SCON,#52h
     MOV   DACCON,#01Fh  ;SET BOTH DACS ON , 12 BIT , ASYNC
     MOV   DACOH,#OOH    ;SET  OUTPUT ON DAC0 TO 0 VOLT
     MOV   DACOL,#OOH
     MOV   DAC1L,#OOH    ;SET OUTPUT ON DAC1 TO 0 VOLT
     MOV   DAC1H,#OOH
MAIN:
      LCALL GETCHAR       ; GET A BYTE FROM UART
      ANL A,#0FH               ; MASK HIGH NIBBLE
      MOV DACOH,A          ; PUT ON DAC SFR
      LCALL GETCHAR
      MOV DAC0L,A
      JMP MAIN
GETCHAR:
       JNB RI,$
       MOV A,SBUF
       CLR RI
       RET
