The output of AD9954 using frequency sweep
Question asked by KYO on Dec 20, 2012
Latest reply on Dec 22, 2012 by sitti
MCU:SILICON LABS  C8051FX20-TB    晶片:C8051F120
http://www.silabs.com/Support%20Documents/TechnicalDocs/C8051F12x-13x.pdf
evaluation board:ANALOG DEVICES AD9954
http://www.analog.com/static/imported-files/data_sheets/AD9954.pdf
AD9954 evaluation board:
   only use DUT1
   power:VDD_I/O=VCC=3.3V   DVDD=AVDD=1.8V
   U13:PS10、SK、I/O SYNC、PD、CLKMODESEL are ground
       RB_ENABLE don't connect anything
       SCLK、SDIO、PS0、FUD、RESET、CS  connect with Port4 of 8051
   REF_CLK_DUT1  connect to signal generator(5MHz Square wave  500mVpp  offset:250mV)
   because no Oscillator on board.
Why the amplitude of output is changing with frequency?
The horizontal axis  is frequency.        log(1MHz)=6
The vertical axis is amplitude(V)
The sweeping frequency is from 100KHz  to 10MHz.
The difference of amplitude is about 1.76V.
How can I solve this problem?  Let the amplitude is fixed.    Example:  It is always fixed in 3V.
