AD9954 PCBZ  evaluation board  setting
Question asked by KYO on Dec 13, 2012
Latest reply on Dec 18, 2012 by sitti
My English is not good , so don't mind.
MCU:SILICON LABS  C8051FX20-TB    晶片:C8051F120
http://www.silabs.com/Support%20Documents/TechnicalDocs/C8051F12x-13x.pdf
evaluation board:ANALOG DEVICES AD9954
http://www.analog.com/static/imported-files/data_sheets/AD9954.pdf
AD9954 evaluation board:
   only use DUT1
   power:VDD_I/O=3.3V   VCC=DVDD=AVDD=1.8V
   U13:PS0、PS1、OSK、I/O SYNC、PD  are ground
       CLKMODESEL=1.8V,RB_ENABLE don't connect anything
       SCLK、SDIO、FUD、RESET、CS  connect with Port4 of 8051
       SDIO(Logic 1)=2.8V,other Pin(logic 1)為3.3V,I don't know why that happen.
   REF_CLK_DUT1  connect to signal generator(12MHz Square wave  150mVpp  offset:75mV)
   because no Oscillator on board.
Code(use C code):
使用:Silicon Laboratories IDE編輯
http://dropcanvas.com/m70cr
Q1:Why don't I get the data of CFR2 by using SDO?
Q2:No output ?
Q3:Why the logic 1 of SDIO pin is 2.8V
Thank you~~
