Status of ADV7180 HSync output and VSync output during Hardware Reset after power supply
Question asked by Hodaka on Dec 12, 2012
Latest reply on Dec 13, 2012 by Hodaka
I want to the status of ADV7180 HS pin(HSync output) and VS/FILELD pin(VSync output) during hardware reset after power supply.
Therefore, I check the following discussion.
http://ez.analog.com/message/45625#45625
There is the following answer in this discussion.
  "All other digital outputs (including the P7:P0 video pixel output port pins) are tri-stated during a reset."
By this, I understood,
HS pin is tri-state and VS/FIELD pin is tri-state during hardware reset after power supply.
At one customer,
HS pin and VS/FIELD pin is pull-up by 47kohm register on an evaluation circuit that they made.
When they measured each status of HS pin and VS/FILED pin during hardware reset,
It occurred that HS pin is low and VS/FIELD pin is low.
"HS pin is tri-state and VS/FIELD pin is tri-state during Hardware Reset after power supply." is wrong ?
Please teach a right status of HS pin and VS/FILED pin during hardware reset.
Best regards.
