AD9548 - Sync on Phase Lock
Question asked by Fred1 on Dec 5, 2012
Latest reply on Dec 6, 2012 by pkern
I am having trouble with the self disciplining feature of the AD9548 PLL.
- I am using 2 EV-Boards with identical settings and output divider settings.
- Both boards are set in self disciplining mode on phase lock.
- The input reference is phase master
- The PLL output frequency is set to 230MHz which goes in the divider network to produce e.g. 10MHz on OUT1.
There is now the following issue:
- After the PLL is phase locked and synchronized the output divider, the 10 MHz signals of both boards should be phase aligned.
- In reality they can be +/-4.3ns ( one 230MHz period) misaligned which is not acceptable for my application.
Is there a way to improve the synchronization between the 2 boards so they will synchronize at the same 230MHz zero crossing?
The 230MHz frequency is phase aligned on both boards so this is not the problem...
Fred
