ad9832 strange behavior
Question asked by Alf on Nov 30, 2012
Latest reply on Dec 12, 2012 by Alf
Hi! I am trying to build a sine waveform generator using ad9832. I already read the topics here with another people having problems with ad9832 but i didn't find the answer so i decided to post this question as a new one.
The problem is, that i am getting nothing on the output of ad9832, but in my opinion the communication with dds is correct (i have programming examples from AD). I attached my schematic to this post. Everything is similar to the datasheet of the ad9832, except the capacitor beetwen refin and agnd (i used 100nF instead of 10nF, does it make any difference ?). Very important thing is, that when i am measuring dc voltage beetwen refout and agnd i am getting something about 200mV. Here is the code for uC which steers ad9832:
void Podziel_Slowo(void)
czesc_slowa[0] = (uint8_t)(slowo&255); // less important 8 bits
czesc_slowa[1] = (uint8_t)((slowo>>8)&255);
czesc_slowa[2] = (uint8_t)((slowo>>16)&255);
czesc_slowa[3] = (uint8_t)((slowo>>24)&255); // most important 8 bits
}// this function divides 32-bit frequency word into the 8-bits parts
void InitSoftSPI_DDS(void)
//outputs MOSI, SCK, CS
DDRD |= (1<<DMOSI)|(1<<DSCK)|(1<<DCS);
PORTD |= (1<<DMOSI)|(1<<DSCK)|(1<<DCS); // everything on "1" at the beggining
}//this one inits the uC pins for soft spi communication
//here are the definitions:
#define DMOSI PD3
#define DSCK PD4
#define DCS PD5
#define DSCK_0 PORTD &= ~(1<<DSCK)
#define DSCK_1 PORTD |= (1<<DSCK)
#define DMOSI_0 PORTD &= ~(1<<DMOSI)
#define DMOSI_1 PORTD |= (1<<DMOSI)
//this function is an spi communication (sends 8-bit data)
void SendSoftSPI_DDS(uint8_t bajt)
uint8_t cnt = 128; //0b10000000
    while(cnt)
        _delay_ms(4);
        if(bajt&cnt) DMOSI_1;
        else DMOSI_0;
        _delay_ms(3); //3000
        DSCK_0;
        DSCK_1;
        cnt>>=1; //cnt = cnt>>1
//and finally this is the function which program dds:
void Wyslij_Freq_pozazakresem(void)
    Podziel_Slowo();
    PORTD &= ~(1<<DCS);    //set 0 on CS (communication active)
    SendSoftSPI_DDS(0b11111000);//turn dds into programming mode
    SendSoftSPI_DDS(0b00000000);//data = dont care
    _delay_ms(2);
    PORTD |= (1<<DCS); //
    _delay_ms(2);  //2000
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00110000); / FREQ0 8L LSB
    SendSoftSPI_DDS(czesc_slowa[0]); //data
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00100001); //iFREQ0 8H LSB
    SendSoftSPI_DDS(czesc_slowa[1]);
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00110010); //FREQ0 8L MSB
    SendSoftSPI_DDS(czesc_slowa[2]);
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00100011);    //FREQ1 8L LSB
    SendSoftSPI_DDS(czesc_slowa[3]);
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    //-------------------- freq1 ----------------------------
    SendSoftSPI_DDS(0b00110100);
    SendSoftSPI_DDS(czesc_slowa[0]); //freq1 8l lsb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00100101);
    SendSoftSPI_DDS(czesc_slowa[1]); //freq1 8h lsb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00110110);
    SendSoftSPI_DDS(czesc_slowa[2]); //freq1 8l msb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00100111);
    SendSoftSPI_DDS(czesc_slowa[3]); //freq1 8h msb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    //----------------phase registers = we will wrtie zeros----------------------------------
    SendSoftSPI_DDS(0b00011000); //ph0 8 lsb
    SendSoftSPI_DDS(0b00000000); //
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00001001); //ph0 8 msb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00011010); //ph1 8 lsb
    _delay_ms(2);
    PORTD |= (1<<DCS); //)
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00001011); //ph1 8 msb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00011100); //ph2 8 lsb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00001101); //ph2 8 msb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00011110); //ph3 8 lsb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00001111); //ph3 8 msb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    //----------------selsrc i sync-----------
    SendSoftSPI_DDS(0b10000000);
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b11000000);
    SendSoftSPI_DDS(0b00000000); // wake up ang generate : )
    _delay_ms(2);
I would like to add that the fselect pin is tied to gnd (i am using pins to select freq registers)
Today at school i checked the spi communication on the osciloscope and it looked correct (sorry i didn't shot any photo's).
Is it possible that ad9832 is broken or something ?
