Trouble sharing code across modules
Question asked by ChrisW679 on Nov 27, 2012
Latest reply on Nov 28, 2012 by JJoseph
in my application there is a table which I want to share with another module. The table is implemented as a variable in the first module:
#pragma section("seg_dmda")
float32_t gl_gain_values[19];
To allow other modules to access a particular index in this table I am sharing the following function:
void GetGalaGain(float32_t* gain, int32_t step)
    *gain = gl_gain_values[step];
My LDF file contains:
KEEP(_GetGalaGain)
and the linker command looks like this:
elf2dyn -o "${ProjName}".dyn -e _BPROCESS_GalaTableAlgo -e _GetGalaGain "${ProjName}".dxe
The module which uses the function includes the symbol in its XML file:
<symbol name="_GetGalaGain" index="0" />
The function is then referenced using a function pointer:
void (*pfSSnModule)(float32_t* gain, int32_t step);
pfSSnModule = (void (*)(float32_t* gain, int32_t step))pSymbol[1];
pfSSnModule(&pGala_Params->m_gain, pGala_Params->m_gala_step);
It does not seem to be working, i.e. it somehow crashes when I add both modules in SigmaStudio.
I am using CCES 1.0.1.0. The patch has been installed.
Can anybody see what I am doing wrong?
BR
Christopher
