AD9789 VSB Modulator MER(SNR) issues
Question asked by Harry.Cho on Nov 15, 2012
Latest reply on Nov 18, 2012 by Harry.Cho
Dear All,
I have designed direct up conversion VSB modulator using AD9789+AD9516+AD914+FPGA and most of circuits are same with ADI evaluation board. My Fdac clock is 2.410Ghz and SRRC doing FPGA in my design. I have measured 38dB of  MER(SNR) in 57MHz and  24dB at 861MHz.  I have measured MER in  valid frequency range between 57MHz to 861MHz. I found that MER is slightly decreasing when I go higher frequency range. Is this normal situation? If not, please advice me how to increase MER in high frequency band.
My setting values of AD9789 are as following;
write_ad9789(0x30,0x80);
write_ad9789(0x31,0xf0);
write_ad9789(0x32,0x9e);
// harry test
write_ad9789(0x36,0x00);
write_ad9789(0x38,0x00);
// mu
write_ad9789(0x24,0x00);
write_ad9789(0x24,0x80);
write_ad9789(0x2f,0xff);
write_ad9789(0x33,0x42);
write_ad9789(0x39,0x4e);
write_ad9789(0x3a,0x6c);
write_ad9789(0x03,0x00);
write_ad9789(0x04,0xfe);
write_ad9789(0x03,0x0c);
write_ad9789(0x33,0x43);
//Set up digital datapath.
write_ad9789(0x06,0xd0);
// bast work around by harry
write_ad9789(0x08,0x48);
write_ad9789(0x09,0x15);
// nco 0 frequency tuning word register
//A9E7FF(100mhz for test purpose)
write_ad9789(0x0a,0xff);
write_ad9789(0x0b,0xe7);
write_ad9789(0x0c,0xa9);
// Rate converter q
//800000
write_ad9789(0x16,0x00);
write_ad9789(0x17,0x00);
write_ad9789(0x18,0x80);
// Rate converter p
//700000
write_ad9789(0x19,0x00);
write_ad9789(0x1a,0x00);
write_ad9789(0x1b,0x70);
// bpf center frequency
//A9E
write_ad9789(0x1c,0x9e);
write_ad9789(0x1d,0x0a);
// interface configuration register
write_ad9789(0x20,0x00);
write_ad9789(0x21,0x59);
// dco frequency
// internal clock phase adjust
write_ad9789(0x22,0x20);
write_ad9789(0x23,0x00);
// channel gain
// if 0 -> rf mute
write_ad9789(0x25,0x00);
// write spectral inversion
write_ad9789(0x29, 0);
// write full scale current -20ma full scale range
write_ad9789(0x3c,0x00);
write_ad9789(0x3d,0x02);
do
rdata = read_ad9789(0x04);
_delay_ms(1);
while (rdata != 0x08);
// update frequency register
write_ad9789(0x1e,0x80);
// update interface clock
// only channel 0 enable
write_ad9789(0x05,0x01);
