ISP1362  U-disk mount failed
Question asked by fuhui on Nov 15, 2012
Latest reply on Nov 23, 2012 by Aaronwu
My board can find the U-disk,but It can't mount.
And as I know , I think the reason is mine kernel configuration is not right or lacks some items.
The next is my logging information.
I hope I can get help from the forum.
Linux version 3.0.8-ADI-2011R1 (root@witchfox-desktop) (gcc version 4.5.3 (ADI-2011R1-RC4_45) ) #420 Fri Nov 16 10:32:36 CST 2012
register early platform devices
bootconsole [early_shadow0] enabled
bootconsole [early_BFuart0] enabled
early printk enabled on early_BFuart0
Board Memory: 64MB
Kernel Managed Memory: 64MB
Memory map:
  fixedcode = 0x00000400-0x00000490
  text      = 0x00001000-0x00169528
  rodata    = 0x00169528-0x001e1f28
  bss       = 0x001e2000-0x001f5610
  data      = 0x001f5610-0x0020c000
    stack   = 0x0020a000-0x0020c000
  init      = 0x0020c000-0x00769000
  available = 0x00769000-0x03f00000
  DMA Zone  = 0x03f00000-0x04000000
Hardware Trace active and enabled
Boot Mode: 0
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF561 Rev 0.5
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 125 MHz core clock and 50 MHz System Clock
NOMPU: setting up cplb tables
Instruction Cache Disabled for CPU0
Data Cache Enabled for CPU0
  External memory: cacheable (write-through) in data cache
  L2 SRAM        : cacheable (write-through) in data cache
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 16002
Kernel command line: root=/dev/mtdblock0 rw clkin_hz=25000000 earlyprintk=serial,uart0,57600 console=ttyBF0,57600 ip=192.168.1.101:192.168.1.100:192.168.1.1:255.255.255.0:BF561-ezkit:eth0:off
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory available: 56316k/65536k RAM, (5492k init code, 1441k kernel code, 651k data, 1024k dma, 612k reserved)
NR_IRQS:153
Configuring Blackfin Priority Driven Interrupts
console [ttyBF0] enabled, bootconsole disabled
Calibrating delay loop... 237.82 BogoMIPS (lpj=475648)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (16 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 16 KB (4 KB free)
Blackfin L2 SRAM: 128 KB (128 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
ezkit_init(): registering device resources
bio: create slab <bio-0> at 0
SCSI subsystem initialized
spi spi0.1: Warning: SPI CPHA not set: Slave Select not under software control!
See Documentation/blackfin/bfin-spi-notes.txt
bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 1.0, regs@ffc00500, dma channel@16
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Switching to clocksource bfin_cs_cycles
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
debug-mmrs: setting up Blackfin MMR debugfs
msgmni has been set to 109
io scheduler noop registered (default)
bfin-uart: Blackfin serial driver
bfin-uart.0: ttyBF0 at MMIO 0xffc00400 (irq = 35) is a BFIN-UART
bfin-dma: initialized
brd: module loaded
physmap platform flash device: 00800000 at 20000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000020 Chip ID 0x00227e
Amd/Fujitsu Extended Query Table at 0x0040
  Amd/Fujitsu Extended Query version 1.3.
physmap-flash.0: CFI contains unrecognised boot bank location (1). Assuming bottom.
number of CFI chips: 1
Using physmap partition information
Creating 5 MTD partitions on "physmap-flash.0":
0x000000000000-0x000000040000 : "bootloader(nor)"
0x000000040000-0x000000200000 : "linux kernel(nor)"
0x000000200000-0x0000007f0000 : "file system(nor)"
0x0000007f0000-0x0000007fe000 : "config(nor)"
0x0000007fe000-0x000000800000 : "u-boot env(nor)"
dm9000 Ethernet Driver, V1.31
eth0: dm9000a at 2c000000,2c000004 IRQ 81 MAC: 08:00:3e:26:0a:5b (chip)
driver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd.0: ISP1362 Host Controller
isp1362-hcd isp1362-hcd.0: new USB bus registered, assigned bus number 1
isp1362_hc_reset:
isp1362-hcd isp1362-hcd.0: irq 82, io mem 0x24030000
isp1362_hc_start:
isp1362-hcd isp1362-hcd.0: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd.0:   ISTL:    2 *  256:      512 @ $0000:$0100
isp1362-hcd isp1362-hcd.0:   INTL:   16 * ( 64+8):  1152 @ $0200
isp1362-hcd isp1362-hcd.0:   ATL :   32 * ( 64+8):  2304 @ $0680
isp1362-hcd isp1362-hcd.0:   USED/FREE:   3968       128
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ISP1362 Host Controller, irq 82
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
bfin-wdt: initialized: timeout=20 sec (nowayout=0)
TCP cubic registered
dm9000 dm9000: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
IP-Config: Complete:
     device=eth0, addr=192.168.1.101, mask=255.255.255.0, gw=192.168.1.1,
     host=BF561-ezkit, domain=, nis-domain=(none),
     bootserver=192.168.1.100, rootserver=192.168.1.100, rootpath=
dma_alloc_init: dma_page @ 0x02788000 - 256 pages at 0x03f00000
Freeing unused kernel memory: 5492k freed
usb 1-2: new full speed USB device number 2 using isp1362-hcd
scsi0 : usb-storage 1-2:1.0
scsi 0:0:0:0: Direct-Access     Kingston DT 101 G2        PMAP PQ: 0 ANSI: 0 CCS
sd 0:0:0:0: [sda] 7831552 512-byte logical blocks: (4.00 GB/3.73 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Asking for cache data failed
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda: sda4
sd 0:0:0:0: [sda] Attached SCSI removable disk
                           _____________________________________
        a8888b.           / Welcome to the uClinux distribution \
       d888888b.         /       _     _                         \
       8P"YP"Y88        /       | |   |_|            __  __ (TM)  |
       8|o||o|88  _____/        | |    _ ____  _   _ \ \/ /       |
       8'    .88       \        | |   | |  _ \| | | | \  /        |
       8`._.' Y8.       \       | |__ | | | | | |_| | /  \        |
      d/      `8b.       \      \____||_|_| |_|\____|/_/\_\       |
     dP   .    Y8b.       \   For embedded processors including   |
    d8:'  "  `::88b        \    the Analog Devices Blackfin      /
   d8"         'Y88b        \___________________________________/
  :8P    '      :888
   8a.   :     _a88P         For further information, check out:
._/"Yaa_:   .| 88P|            - http://blackfin.uclinux.org/
\    YP"    `| 8P  `.          - http://docs.blackfin.uclinux.org/
/     \.___.d|    .'           - http://www.uclinux.org/
`--..__)8888P`._.'  jgs/a:f    - http://www.analog.com/blackfin
Have a lot of fun...
BusyBox v1.18.4 (2012-03-09 16:43:21 CST) hush - the humble shell
root:/> ls -l /dev/sda4
brw-rw----    1 root     root        8,   4 Jan  1 00:00 /dev/sda4
root:/> mount /dev/sda4 /mnt
mount: mounting /dev/sda4 on /mnt failed: No such device
Thank you.
