BF548 crash when removing USB stick
Question asked by Uli on Nov 11, 2012
Latest reply on Nov 12, 2012 by Uli
Hi all,
we are successfully running uCLinux 3.2.0-ADI-2012R1-pre on a custom board with USB and SCSI enabled to mount USB memory sticks. While this works well in general, there is a problem when the system gets low on memory -- in which case an inserted stick is recognized but mdev obviously can not allocate enough memory when the stick is *removed*:
Aug 12 08:41:12 blackfin user.notice kernel: sd 1:0:0:0: [sda] Attached SCSI removable disk
Aug 12 08:41:19 blackfin user.info kernel: usb 1-1: USB disconnect, device number 3
Aug 12 08:41:19 blackfin user.warn kernel: mdev: page allocation failure: order:7, mode:0xd0
Aug 12 08:41:19 blackfin user.notice kernel: Stack info:
Aug 12 08:41:19 blackfin user.notice kernel:  SP: [0x02629ca4]
Aug 12 08:41:19 blackfin user.notice kernel:  Memory from 0x02629ca0 to 0262a000
Aug 12 08:41:19 blackfin user.notice kernel: Return addresses in stack:
Aug 12 08:41:19 blackfin user.warn kernel: Mem-Info:
Aug 12 08:41:19 blackfin user.warn kernel: DMA per-cpu:
Aug 12 08:41:19 blackfin user.warn kernel: CPU    0: hi:    0, btch:   1 usd:   0
Aug 12 08:41:19 blackfin user.warn kernel: Allocation of length 483328 from process 689 (mdev) failed
Aug 12 08:41:19 blackfin user.warn kernel: active_anon:0 inactive_anon:0 isolated_anon:0
Aug 12 08:41:19 blackfin user.warn kernel:  active_file:53 inactive_file:72 isolated_file:0
Aug 12 08:41:19 blackfin user.warn kernel:  unevictable:923 dirty:0 writeback:0 unstable:0
Aug 12 08:41:19 blackfin user.warn kernel:  free:1985 slab_reclaimable:461 slab_unreclaimable:370
Aug 12 08:41:19 blackfin user.warn kernel:  mapped:0 shmem:0 pagetables:0 bounce:0
Aug 12 08:41:19 blackfin user.warn kernel: DMA free:7940kB min:4096kB low:5120kB high:6144kB active_anon:0kB inactive_anon:0kB active_file:212kB inactive_file:288kB unevictable:3692kB isolated(anon):0kB isolated(file):0kB present:46736kB mlocked:0kB dirty:0kB writeback:
Aug 12 08:41:19 blackfin user.warn kernel: lowmem_reserve[]: 0 0 0
Aug 12 08:41:19 blackfin user.warn kernel: DMA: 105*4kB 72*8kB 40*16kB 17*32kB 20*64kB 13*128kB 9*256kB 1*512kB 0*1024kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB 0*32768kB = 7940kB
Aug 12 08:41:19 blackfin user.warn kernel: 1048 total pagecache pages
Aug 12 08:41:19 blackfin user.warn kernel: Unable to allocate RAM for process text/data, errno 12
Specifically, it looks like the kernel needs at least one 1024k block of memory to successfully re-init USB driver(s). Does anyone have experience with this or does anyone know a more light-weight way of accessing USB sticks from ucLinux?
Thanks, Ulrich
