Kernel for Zync zc702 board fails to boot (crash, hang)
Question asked by milosoftware on Nov 7, 2012
Latest reply on Jun 18, 2013 by larsc
I've compiled the ADI kernel, building the "xcomm_zynq" branch from "git://github.com/analogdevicesinc/linux.git"
When attempting to boot this kernel, I get the following output, and it hangs or crashes, please help:
U-Boot 2012.04.01-00304-g7639205-dirty (Nov 02 2012 - 15:05:09)
DRAM:  1 GiB
WARNING: Caches not enabled
MMC:   SDHCI: 0
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   zynq_gem
Hit any key to stop autoboot:  0
zynq-uboot> setenv bootargs console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait
zynq-uboot> run sdboot
Copying Linux from SD to RAM...
Device: SDHCI
Manufacturer ID: 3
OEM: 5344
Tran Speed: 25000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading uImage
2907704 bytes read
reading devicetree.dtb
16648 bytes read
## Booting kernel from Legacy Image at 000079c0 ...
   Image Name:   Linux-3.3.0-yocto-standard
   Created:      2012-11-06  14:54:18 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2907640 Bytes = 2.8 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x02a00000
   Loading Kernel Image ... OK
OK
   Loading Device Tree to 1fff8000, end 1ffff107 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0
Linux version 3.3.0-yocto-standard (mike@paradigit) (gcc version 4.7.2 (GCC) ) #1 SMP PREEMPT Tue Nov 6 15:54:09 CET 2012
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Xilinx Zynq Platform, model: Xilinx Zynq ZC702
bootconsole [earlycon0] enabled
Memory policy: ECC disabled, Data cache writealloc
BUG: mapping for 0xf8f00000 at 0xfe00c000 out of vmalloc space
BUG: mapping for 0xe0001000 at 0xfe001000 out of vmalloc space
BUG: mapping for 0xffff1000 at 0xfe200000 out of vmalloc space
PERCPU: Embedded 7 pages/cpu @c123e000 s6400 r8192 d14080 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 256000
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 240MB 768MB = 1008MB total
Memory: 1012604k/1012604k available, 35972k reserved, 303104K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xee000000 - 0xfd000000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xed800000   ( 728 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc04c2ee4   (4844 kB)
      .init : 0xc04c3000 - 0xc04e7900   ( 147 kB)
      .data : 0xc04e8000 - 0xc051fc80   ( 224 kB)
       .bss : 0xc051fca4 - 0xc0a283ab   (5154 kB)
Preemptible hierarchical RCU implementation.
        RCU lockdep checking is enabled.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:128
xlnx,ps7-ttc-1.00.a #0 at 0xee000000, irq=43
Console: colour dummy device 80x30
Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
... MAX_LOCKDEP_SUBCLASSES:  8
... MAX_LOCK_DEPTH:          48
... MAX_LOCKDEP_KEYS:        8191
... CLASSHASH_SIZE:          4096
... MAX_LOCKDEP_ENTRIES:     16384
... MAX_LOCKDEP_CHAINS:      32768
... CHAINHASH_SIZE:          16384
memory used by lock dependency info: 3695 kB
per task-struct memory footprint: 1152 bytes
Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
smp_twd: clock not found: -2
Calibrating local timer... 399.24MHz.
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
Setting up static identity map for 0x35f7d0 - 0x35f804
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (3188.32 BogoMIPS).
devtmpfs: initialized
------------[ cut here ]------------
WARNING: at /home/mike/zynq/build/tmp-eglibc/work/zynq_zc702-oe-linux-gnueabi/linux-adi-3.6+git1+0f8dd21d5a75da378066468228eba
03333f2b4cf-r0/linux/arch/arm/mm/dma-mapping.c:198 consistent_init+0x70/0x104()
Modules linked in:
[<c0013004>] (unwind_backtrace+0x0/0xe0) from [<c001f3b8>] (warn_slowpath_common+0x4c/0x64)
[<c001f3b8>] (warn_slowpath_common+0x4c/0x64) from [<c001f3e8>] (warn_slowpath_null+0x18/0x1c)
[<c001f3e8>] (warn_slowpath_null+0x18/0x1c) from [<c04c5bcc>] (consistent_init+0x70/0x104)
[<c04c5bcc>] (consistent_init+0x70/0x104) from [<c0008594>] (do_one_initcall+0x90/0x164)
[<c0008594>] (do_one_initcall+0x90/0x164) from [<c04c3828>] (kernel_init+0x8c/0x12c)
[<c04c3828>] (kernel_init+0x8c/0x12c) from [<c000e470>] (kernel_thread_exit+0x0/0x8)
---[ end trace 1b75b31a2719ed1c ]---
Modules linked in:
---[ end trace 1b75b31a2719ed1d ]---
NET: Registered protocol family 16
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72360000, Cache size: 524288 B
registering platform device 'pl330' id 0
registering platform device 'arm-pmu' id 0
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
MIO pin 47 not assigned(00001220)
xslcr xslcr.0: at 0xF8000000 mapped to 0xEE008000
bio: create slab <bio-0> at 0
gpiochip_add: registered GPIOs 0 to 245 on device: xgpiops
xgpiops e000a000.gpio: gpio at 0xe000a000 mapped to 0xee00a000
