Measuring impedance with AD5933 and MSP430G2553, but slow
Question asked by slund89 on Nov 6, 2012
Latest reply on Nov 6, 2012 by musach
Hello
I'm interfacing the AD5933 with a microcontroller (MSP430G2553), and are making successful readings, both temperature and real/imag data. Unfortunately it takes too much time compared to the USBinterface to the PC. It takes about 10 seconds to make 10 frq increments and readings, and the computer does 100 increments and readings in 1 second.
I hope some of you have an idea what i should do different.
Kindest regards Simon
The code is as below:
void StartFrqSwp(void)
    //PROGRAM x Hz to the START FREQUENCY register
    ei_vI2cWriteTwo(Freq_low, StartFrequencybyte0);
    ei_vI2cWriteTwo(Freq_mid, StartFrequencybyte1);
    ei_vI2cWriteTwo(Freq_high, StartFrequencybyte2);
    //The sweep is going to have x points in hex
    ei_vI2cWriteTwo(NumInc_low, NumberIncrementbyte0);
    ei_vI2cWriteTwo(NumInc_high, NumberIncrementbyte1);
    //The sweep is going to have a frequency increment of x Hz between successive points in the sweep
    ei_vI2cWriteTwo(FreqInc_low, FrequencyIncrementbyte0);
    ei_vI2cWriteTwo(FreqInc_mid, FrequencyIncrementbyte1);
    ei_vI2cWriteTwo(FreqInc_high, FrequencyIncrementbyte2);
    //The DDS is going to output 15 cycles of the output excitation voltage before the ADC will start sampling
    //The settling time cycle multiplier is set to x1
    ei_vI2cWriteTwo(NumSettle_low, SettlingTimebyte0);
    ei_vI2cWriteTwo(NumSettle_high, SettlingTimebyte1);
    //Standby mode command = B0 hex
    ei_vI2cWriteTwo(Control_high, StandbyMode);
    ei_vI2cWriteTwo(Control_low, 0x08);        //Enable external Oscillator
    ei_vI2cWriteTwo(Control_high, 0x01);    //Set the output excitation range to be 2vp-p and the PGA setting to = x1
    ei_vI2cWriteTwo(Control_high, Reset);    //Initialize Sensor with Start Frequency
    msDelay(2);
    ei_vI2cWriteTwo(Control_high, 0x20);    //Start Frequency Sweep
void ReadFrqSwp(void){
    EraseBuffer();
    StatusNum = ei_uiI2cRead(Status);
    StatusNum = StatusNum & 0x04;        //00000100 = Frequency sweep complete
    while(StatusNum != 0x04 && place_counter<(NumberIncrementbyte0))            //as long as sweep hasn't completed
        StatusNum = StatusNum & 0x02;    //00000010 = valid real and imaginary data available
        while (StatusNum != 0x02){        //(!(ei_uiI2cRead(Status) & 0x02))
            //if(StatusNum == 0x02){
                //do nothing, proceed with sweep
            //else{
                ei_vI2cWriteTwo(Control_high, 0x40);        //repeat sweep point
            remeasures++;
        SaveFrqMeas();
        place_counter++;
        ei_vI2cWriteTwo(Control_high, 0x30);    //Increment to next frequency point
void SaveFrqMeas(void)
    RxBuffer[0] = ei_uiI2cRead(Real_high);
    RxBuffer[1] = ei_uiI2cRead(Real_low);
    RealData = (RxBuffer[0]<<8)+RxBuffer[1];
    if (RealData <= 0x7FFF){
        //number is positive
    else{
        RealData = RealData & 0x7FFF;
        RealData = RealData-65536;
    RealBuffer[place_counter] = RealData;
    RxBuffer[0] = ei_uiI2cRead(Imag_high);
    RxBuffer[1] = ei_uiI2cRead(Imag_low);
    ImagData = (RxBuffer[0]<<8)+RxBuffer[1];
    if (ImagData <= 0x7FFF){
    else{
        ImagData = ImagData & 0x7FFF;
        ImagData = ImagData-65536;
    ImagBuffer[place_counter] = ImagData;
