BF512, PPI, DMA0 and AD7622 adc
Question asked by Fred3d on Nov 5, 2012
Latest reply on Nov 8, 2012 by Prashant
I am trying to use System Services to operate an AD7622 A/D converter.  The ADC is connected to the PPI and I have programmed the DMA.  I have connected the AD7622's BUSY signal to the BlackFin's DMAR0 (PG2) pin.  I can not find an adi_dma_Control() command to specify that I am using DMAR0.  Both the PORTG_MUX and PORTG_FER registers have the wrong values.  Here is my initialization code:
   ADI_DMA_MANAGER_HANDLE  dmaHandle;
   ADI_DCB_HANDLE          dcbPpiServer;
   ADI_DMA_CHANNEL_HANDLE  pDmaPpiChannelHandle;
   ADI_DMA_RESULT          dma_result;
   ADI_DMA_CONFIG_REG      dma_config_register;
   dmaResult = adi_dma_Init (&dmaManager_workspace, DMA_MGR_WS,
                             &dmaDevices, &dmaHandle,
                             &dmaCriticalRegionArg);
   dma_result = adi_dma_Open (dmaHandle,
                              ADI_DMA_DMA0,   // DMA 0 - default for PPI.
                              NULL,
                              & pDmaPpiChannelHandle,
                              ADI_DMA_MODE_CIRCULAR,
                              dcbPpiServer,
                              copy_buffer);
    /* Circular; Call back on sub-buffer complete */
    dma_config_register.b_DMA2D  = ADI_DMA_DMA2D_LINEAR;
    dma_config_register.b_NDSIZE = ADI_DMA_NDSIZE_STOP;
    dma_config_register.b_WDSIZE = ADI_DMA_WDSIZE_16BIT;
    dma_config_register.b_DI_SEL = ADI_DMA_DI_SEL_INNER_LOOP;
    dma_config_register.b_DI_EN  = ADI_DMA_DI_EN_ENABLE;
    dma_config_register.b_WNR    = ADI_DMA_WNR_WRITE;
    dma_config_register.b_FLOW   = ADI_DMA_FLOW_AUTOBUFFER;
   dma_result = adi_dma_Buffer(pDmaPpiChannelHandle,
                               pingPong,
                               dma_config_register,
                               ARRAY_SIZE,
                               2u,         /* 2 Bytes = 16-bit datum */
                               2u,         /* 2 sub-buffers */
                               0u);        /* Ignored value */
  dma_result = adi_dma_Control (pDmaPpiChannelHandle,
                                ADI_DMA_CMD_SET_DATAFLOW,
                                DMA_ENABLE);
I suspect I am NOT doing some needed initialization, but I am stumped.  Any ideas?  Thanks.
Fred
